Question about Feiyue FS288
Can Feiyue FS288 be Modified to same as Sailrite Ultrafeed LSZ1?
Apparently the Feiyue FS288 can be Modified to be same as Sailrite Ultrafeed LSZ1?
Does anyone what parts would be needed to do this?
Are the machines otherwise identical?
Fabric bunching sailrite
try easing both bobbin and top thread tensions
Dec 25, 2013 | Sailrite Ultrafeed LSZ-1 Mechanical Sewing...
Where can I buy an electrical supply and foot control for a Thompson Mini Walking foot Model PW 201
Almost any dealer will sell a replacement part for the sailrite. Its a standard type controller, the cost is 40-80 depending on the quality of the controller and cord. Take the machine in the shop and try to be sure its a correct fit. Sailrite has a mail service as well.
Derek
Jan 18, 2011 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
Ultrafeed LS-1 Deluxe Mechanical Sewing Machine: I don't know this machine. I just plugged it in &a...
You need purchase a foot control and a "motor and light block" to be able to control the speed of the machine. The machine plugs into the terminal marked motor on the motor and light block.
May 06, 2010 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
Looking for user manual for Sailrite LS-1 and a source for a basic case for the same.
Go to the Sailrite site, open the "sewing machine" menu and choose "accesories". The is a case on the list which might be suitable.
Although I couldn't see any instructions option, the manufacturer should be able to supply one if you ask them, since they pubished it in the first place.
Dec 18, 2009 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
BOBBIN TREAD LOOPING UNDERNEATH
looping thread on the bobbin side means that the upper tension is too loose... make sure it's threaded correctly.
Jun 14, 2009 | Feiyue FS288
Basic instruction to use the Sailrite Ultrafeed LSZ-1
I CAN'T HELP YOU WITH THE MANUAL, BUT I CAN TELL YOU THAT MOST MACHINES THREAD ABOUT THE SAME. IT SOUNDS LIKE THIS MAYBE A COMMERCIAL MACHINE, AND I WANTED TO WRITE JUST TO TELL YOU TO BE VERY CAREFUL. WITH A COMMERCIAL MACHINE YOU CAN SEW OVER YOUR FINGERS WITHOUT EVEN KNOWING. FOR EXAMPLE, SAY A REGULAR HOME SEWING MACHINE HAS 1,500 rpms, THE EQUALIVENT IN A COMMERCIAL MACHINE IS 15,000 RPMS. THERE IS POWER AND SPEED. I AM NOT FAMILIAR WITH THIS PARTICULAR MACHINE, BUT WANTED TO TELL YOU TO JUST PUT THE BANDAIDS ON YOUR FINGERS FIRST, BECAUSE IF IT IS A COMMERCIAL MACHINE, IT WILL REQUIRE YOU TO DO A LITTLE BIT OF PRACTICE FIRST BEFORE YOU "PUT THE PEDDLE TO THE METEL".
Aug 11, 2008 | Sailrite Ultrafeed LSZ-1 Mechanical Sewing...
Sewing manual for a Reliable or Sailrite
The problem is that you purchased a clone of the Sailrite Ultrafeed. Most people do not know how much work Sailrite puts into each Ultrafeed Sewing Machine before it is shipped to customers. They hold 17 patents on the Zigzag Ultrafeed and know this machine inside and out. So when each machine goes through the assembly line in Indiana they are then tested by Sailrite in 2 layers of canvas then 8 layers of canvas then 4 layers of vinyl fabric if it does not sew it flawlessly they fix it, Ultrafeeds work right out of the box! So, it is highly unlikely that you will be able to get the clone machine to work. It must be totally rebuilt (a 4 hours process for an experienced technician). Sailrite will not work on any clone machines. So get your money back and buy a Sailrite Ultrafeed! If you are desperate and can not return the machine you can buy a DVD that Sailrite made for the Ultrafeed (each Ultrafeed purchased gets it free) it can be purchase here: http://www.sailrite.com/Ultrafeed-Advanced-Maintenance-DVD . It will help with timing issues, but will not show you how and what to do to rebuild the machine.
May 21, 2008 | Sailrite Ultrafeed LS-1 Mechanical Sewing...
Needles for Thompson Waling foot machine
135 X 17 is the correct sizing. Needles you should use are from #18 to #22. You can order from sailrite.com or from "thompson" the manufacturer is now datco or something, located in Lubbock Texas (do a google search on Thompson mini walking foot sewing machine)
Oct 13, 2007 | Sailrite Ultrafeed LS-1 Deluxe Mechanical...
Feiyue FS288 Logo
178 people viewed this question
Top Feiyue Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Feiyue Sewing Machine Expert? Answer questions, earn points and help others
