Question about Insignia Digital-to-Analog Converter for Analog TVs
I have old tv with rf connection need to adapt to rca plugs
Need to connect older tv to digital converter
  • 4,234 Answers
Simply insert the converter between the curent cable and the TV. The converter should have come with a short RF cable that you can use between teh converter and the TV. I have incluede a before and after line diagran below.
Dan
BEFORE: cable==> TV
AFTER: Cable==> converter ==>TV
Posted on Feb 25, 2009
Connecting to old Sanyo single RF CONNECTION plug.Not able to view menu operation program from AT103B ematic.Do I need a adapter for this old Tv for connections.Now I'm using a cable and antenna only.
If it is not a flat screen TV yes all TV signals are now digital so even if you are doing the cable and antenna thing you need a digital converter box to convert the signal from digital to analog. Not sure if they still sell them at Wal-Mart, but I am sure you can find one on-line.
Nov 08, 2016 | Sanyo Televison & Video
Connecting Digital Decoder to Analogue TV.
The av channel is 0 and then you need to search on channel 0 as i mean tune into the channel
Sep 14, 2008 | Televison & Video
Connecting wii to Sony bravia tv
If you have an old V.C.R that has Red, White and Yellow sockets for AV and it still works then plug it into the RF socket tune the V.C.R to your TV and connect your Wii to the Red,White and Yellow R.C.A connections and you should be playing in no time. I have done this myself on a new Samsung TV it will work. If you have no V.C.R and you have HDMI sockets in your TV you can buy an adapter to convert the existing AV port on the Wii to HDMI then simply connect a HDMI cable (if you have 1 if not they are cheap enough off eBay starting at $6.00+AUD or around $20.00AUD Retail) to the Wii and then the TV ensuring that both the TV and the Wii are powered down prior to connecting any cables at the back. The HDMI Adapter for Wii is available on eBay from $5.00 AUD to $24.95AUD depending on the country you purchase it from. If all else fails a second TV with Red, White and Yellow RCA plugs will work but also the most expensive of the fixes. All fixes suggested will work. Good Luck I hope this helps.
Jan 12, 2013 | Nintendo Wii Video Game Consoles & Games
Would like to play old Coleco game on LG LCD tv, Comcast Cable HD system....how to hookup ?
Most older game consoles used an RF output (connected to the anenna jack of the TV, tune to channel 3 or 4 to see the game). And most used a RCA plug on the end of a cable to connect. You will need an adapter to go from the RCA plug to an 'F' fitting (like on the end of a cable TV wire) to connect to your television. Then, with the game turned on, you will have to program or scan your TV to find that signal.
May 24, 2011 | Televison & Video
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
I have an older TV with only an antenna hook-up, a VCR, a DVD recorder and a converter box that I would like to hook all together. I can get the VCR to work, but don't really know how to hook the DVD...
Try this. You will need 2 RF cables and a RCA cable that has a red, black, and yellow plug on each end.
  1. Plug the antenna signal into the converter box.
  2. Connect the RF output (TV out) of the converter box to the RF input on the VCR
  3. Connect the RF output (TV out) on the VCR to the TV
  4. Finally, plug the DVD recorder into the converter box also, but use the 3 RCA cables that came with it (audio left, right and video).
Apr 13, 2010 | iLO DVDR05 DVD Recorder
CONNECTING BOX TO TV W/O JACKS
then you will need one of these coax adapters to antenna
Jan 13, 2009 | Insignia Digital-to-Analog Converter for...
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
New TV Converter Boxes
If your talking about a digital converter box, it goes between the antenna and the tv.
May 09, 2008 | Televison & Video
2600 atari
To connect your Atari to your TV, you'll need to get a "phono to f" adapter. These are available at RadioShack (part no. 278-255) for about $5.00 This adapter takes the phono plug from the Atari and changes it to a standard coaxial adapter. If your HD TV doesn't have an input for standard cable wires, you'll need to get yourself an RF modulator to switch the coax to RCA. If you have an old VCR with an unused cable input, that will work as well.
Mar 28, 2008 | Atari 2600 Console
Insignia Digital-to-Analog Converter for Analog TVs Logo
268 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
