Question about Toshiba Satellite A85-S107 Notebook
Touchpad disconnect on satellite a85-s107
Hello,my mouse pad was not working, so I removed the keyboard and discovered, the wire from the mouse pad was disconnected.
I try putting back to where I believe it belong (this would be under the spacebar when the keyboard is installed), but when I insert it in the connection slot, the computer shuts down, and If I do it with the computer shut off, it will not boot up.
is there a diagram I can get to show me where and how the mouse pad wire is connected.
Why has my mouse stopped working, also the touch pad on computer has stopped?????
Janice, This is info from Tomsguide.com
1- Turn off computer, disconnect the power cord, remove the battery.
2- Press the Power On button for 10 seconds
3- Replace battery and/or connect power cord.
4- Turn On computer + immediately press F2 key repeatedly
5- Press F9 then press Enter
6- Press F10 then press Enter
May have virus or corrupt driver, run your anti virus and try reloading divers for mouse and touch pad, you may have to use system restore to an earlier date when thins were working OK.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ccm.net/forum/affich-689275-toshiba-satellite-mouse-pad-stopped-working
Toshiba Satellite keyboard and touchpad don work
Toshiba Satellite Cursor is not responding
Jul 31, 2016 | Toshiba Computers & Internet
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
Need to replace cpu fan on Toshiba Satellite A85-S107 and can not get the laptop appart.
Remove the battery, unplug the unit.
  • Take off the hard drive cover by extracting the two screws that secure it and then taking it off. Take out the screw on the modem and wireless card cover and take the cover off. To remove the hard drive, shift it to the left to disconnect it from the motherboard and pull it out of the computer. Gently disconnect the Wi-Fi card antenna cables and take out the card. Extract the screws on the modem card, disconnect it from the motherboard, and then disconnect the cable to free it from the computer. Remove the optical drive screw, push the drive out of the laptop and then take it off. Extract the 15 screws out of the bottom of the laptop and turn the laptop over.
  • Open the laptop and fold back the LCD screen as far back as possible. Pry up the keyboard bezel (the plastic strip above the keyboard) by inserting a flat-head screwdriver or a spudger in the groove at the right side of the strip. Pull the bezel off the laptop. Extract the keyboard screws and fold the keyboard down over the palm rest. Release the flat cable that connects the keyboard to the motherboard and take the keyboard off the laptop. Remove the screws securing the LCD screen to the back side of the laptop. Disconnect the video cable and the Wi-Fi cable from the motherboard and remove the screws on the LCD screen hinges and then pull the screen off the laptop. There are four visible cables that are connected to the motherboard: the switchboard cable, the speaker cable and the touchpad cable. Disconnect all three. Take out the four screws from the top cover and pry the top cover off by running the flat-head screwdriver along the groove around the entire laptop and pulling it off. Now the laptop is completely disassembled to where the motherboard is exposed as the last remaining component.
May 05, 2011 | Toshiba Satellite A85-S107 Notebook
I have a Toshiba Satellite Laptop. The mouse pad is not working.
You might need a palmrest/touchpad replacement. Check the touchpad cable connection on the motherboard first. Remove it and reinsert in its place. If still not working you have to replace the assemble.
Oct 03, 2009 | Toshiba Computers & Internet
Hi, 2 of the key pads came off at my sisters house can you give me an idea how much it will cost to get them re-installed it seems they are only the top parts & one seems to be sticking
You really can't purchase just the keys alone, you usually have to replace the keyboard itself. My company sells the keyboard for $69.99 for the OEM and $59.99 for compatible keyboard.
Thanks
C2Solutions
Aug 01, 2009 | Toshiba Satellite A85-S107 Notebook
Toshiba a85-s107 satellite laptop - does not power on
Remove the battery and reinstall the battery. It should reboot
Apr 09, 2009 | Toshiba Satellite A85-S107 Notebook
Howto remove key board of Satellite A85-S107
underneath the laptop you will see three or four screw holes with an arrow on them in the centreish of the laptop. remember the keyboard is only in the middle of the laptop and not the edge so no need to undo any more.undo these and open laptop. you should also see two small lumps at the foot of the keyboard either side of the spacebar but lower. this shuold release the main body of the keyboard and allow you to lift as far as your ribbon wire will allow. carefully undo the very small catch at the foot of the ribbon wire and release the wire. don not under any circumstances snap this wire as it will be a very skillfull soldering job to repair the damage.
Feb 06, 2009 | Toshiba (225EXTR5)
Keyboard replacement
Hello this is for uprading the memory , But does show how to remove the keyboard
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A85/replace-laptop-memory-1.htm
Good Luck .Joe
Oct 07, 2008 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Jun 27, 2008 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A85-S107 Notebook Logo
108 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
