Question about Toshiba TE2100 Notebook
Screen adjustment just upgraded to XP and screen has a 1/2 in black line on the right side.
  • jjwarda Apr 25, 2009
    just upgraded to XP Pro and screen has a 1/2 in black line on the right side
  • 115 Answers
You have adjust the screen resolution
1028 X 600
16bit or 32bit
goto control panel----look for appearance and personalization ---screen resolution
Posted on Feb 25, 2009
I recently updated this netbook using the Windows 7 upgrade and went through the entire tech support call with Microsoft regarding accurate procedures to upgrade from xp to Windows 7. The netbook worked...
To let you know one FACT....
MS tech support is JUNK....
If you still want to use them it's you call.....
Solution
Get an external monitor and fix that to the monitor port (watch this video)
http://www.youtube.com/watch?v=J7MZ23T-NRg&feature=fvw
on the back or on side of the notebook serial port
if display on monitor is ok then there is some issue with you laptop display
if hardware is the issue
you need to aproach a tech shop to fix the issue
OS upgrades dont spoil hardwares....
Nov 29, 2010 | ASUS Eee 1008HA Netbook
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Red horizontal curvy lines
You need to turn the voltage on the red tube down slightly, also you would need to adjust focus to compensate for the lower voltage to the red tube. On the left and right bottom side of speaker cover are two round covers, take them out and there are 2 1/4" hex screws take them out carefully take cover off, there is another service cover same hex screws remove. You will see the focus block on the right side, tubes are labled on block. 2 knobs for each tube. Make voltage adjustments while tv is on a black screen, then for focus, turn color all the way off in the menu, and adjust focus until it looks right in black and white. These adjustments should only be very small; if alot of adjustment is needed, you may have other issues.
May 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Installed xp upgrade it won't use the whole screen
Hi ABIDJAN,
Upgrade the video drivers or adjust the setting on the monitor.
Good luck.
Jul 27, 2008 | HP Compaq 6510b Notebook PC
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Toshiba TE2100 Notebook Logo
194 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
