Question about Makita 5620DWD Cordless Circular Saws
I CAN'T GET A BEARING OF MY SAW
I HAVE A 6 1/2 INCH SKILL SAW AND MY BEARING WENT BAD. HOW DO I GET THIS THING OFF?
  • 2,176 Answers
Which bearing we talking about. The spindle bearing has a retainer that screws into the hub the other bearings just need pulled off with a bearing puller. Let me know
Posted on Feb 25, 2009
Runs Rough
The noise you have is armature failure from bearing failure or shortening out from burnt/ worn brushes. It may be poling out from failed bearings/bushes or you have a short in one of the bars in the commutator bars. Have an appliance electrician check it out.
Jun 30, 2013 | Ridgid Saws
Is there any 3G
No 3G on a saw. Maybe on your phone.
Aug 10, 2012 | Metabo 631925000 6-Inch X 3/4-Inch X...
Just replaced speed control unit and saw still spins at very slow rpm, guessing 20-30. any other possibilties. any way to check if new control unit is no good?
With the saw unplugged, turn the saw blade.
If it turns easily with no hangups I would guess its the field.
When mine went bad the blade went backwards very slowly.
I replaced only the field and not the armature and it's worked fine for over 2 yrs.
Right now I have it apart to change an armature bearing which was completely frozen up.
Aug 29, 2011 | Bosch 4000 - 07 Electric Table Saws
I need to replace a ball bearing of a craftsman skill circular saw. Do I need a specialized replacement part (if so where can I find it.) or can I just use a generic ball bearing?
The bearing would be a standard bearing. There's plenty of engineering in bearings and consumer tool manufacturers don't waste their time designing application-specific bearings. It helps a lot if you can read the brand and number on the old bearing. It will also help if you can precisely measure the bearing. There are several bearing distributors on-line that can find the exact same thing or cross- reference for you.
May 20, 2011 | Craftsman Saws
Could I use a 8 Inch DADO 3/4 inch wide blades.
Yes, as long as you have a 10" craftsman skill saw.
Apr 17, 2011 | Craftsman Saws
Bad vibration and noise from saw
Are you sure blade is straight, and mounted on arbor correctly? that's the first thing to check. Or remove blade and 2 arbor plate's and run saw. If you have a vibration after that you have a bearing problem.( rear bearings go bad on these saw's) other they are the best saw for the price. We have about 50 of the 4000 model. hope that help's Never had a vib problem.
Jun 01, 2010 | Bosch 4100 10" Worksite Table Saw
Ihave an old craftsman 9 inch table saw with a capacitor ball bearing motor and I think the capacitor went out the part that is not working corectly acts like a capacitor in a stereo system that is bad in...
I would check the yellow pages under motors electric in your area and take the capacitator there and ask them to check and then match it up. There should be some identifying numbers on it.
Jul 19, 2009 | Craftsman Saws
Need part for model #172.108530 on a craftsman
I went to Searspartsdirect.com and typed in your model number leaving the last 0 off and came up with a schematic, I don't know if this is actually your saw so you might want to take a look and hopefully you can find the part you need. If I have helped you in anyway please rate my information accordingly and Thank you
Apr 25, 2009 | Craftsman Saws
Makita 5620DWD Cordless Circular Saws Logo
232 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
