Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
What caused wires to be burnt at clips that connects to part
306060 ? Dryer tumble but won't heat. Donnie
  • kyle welty May 11, 2010
    if the nuts or screws on the terminal block were not tight when installed will make the wire fry. if heating element went bad it will cause the wire ends to singe because the is power going to them with no where to go and the weakest point of a wire is the connection
  • mlord4 May 11, 2010
    burnt at clipsthat ?bad venting is the 1st thing that lets wire burn & age what mode# how old
  • 686 Answers
That's your cycling thermostat and it's bad also check continuity of your thermal fuse (usually off white and looks like a tilted square) and check your high limit thermostat (closest to the heat element) and also check that the heat element is not broken any place throughout the coil of it. While you have it apart clean out the build up of lint everywhere.
Posted on Apr 06, 2009
Wiring on my timer on white knight tumble dryer 44as asburnt what can cause this
Usually a burnt connection is caused by too much amperage or a loose connection
Aug 31, 2014 | Dryers
Whirlepool electric dryer stopped heating.
This could definitely cause a dryer no heat problem and a potential house fire. Purchase a new dryer cord and replace it. The following link explains how:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Follow the 3-prong wire color code provided. If the new dryer cord does not have any colors (all gray) simply make sure the center conductor gets connected to neutral (WHITE) at the terminal block on the back of the dryer. There should also be a grounding strap or ground wire (GREEN) attached to the neutral at the temrinal block. Each outer wire will then get connected to either of the two hot (RED and BLACK) terminals.
The reason your dryer still may tumble in spite of a bad dryer cord is because the drive motor only uses 110-120VAC while the heating circuits require the full 220 service. If one of the dryer cord conducters is burned in half, you may only be getting half your input voltage to the dryer. A voltage reading across the two hot terminals (left and right slots) at the wall receptacle should read 220-240VAC. You should also read this same voltage across the red and black wires at the terminal block. If not, you have a bad cord.
If you have any questions, please let me know. I hope this helps you.
Jul 29, 2009 | Whirlpool LER5636P Electric Dryer
The tumble dryer is working but not heating??? cleaned all filters and water tank. any ideas???
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. In your case it is better that y ou call in an engineer to test it. Also overloading and blocked filters can cause the thermostat to cut out and they can also go with simple wear and tear. Check your service manual for spare parts etc
Jul 19, 2009 | Dryers
I have a maytag model 747g dryer. I dryer tumbles
The heating element is burnt out. Unplug the dryer. Follow the wires from the control panel. They will go to the heating element. The element is probably held in by anywhere from 2 to 6 screws. Remove the screws and you should be able to pull out the element. The element is coiled wire that heats up when power is applied. If you look closely you can probably see a break in it. To get a replacement you will need the model number which will be on a metal plate either on the back of the dryer or inside the dryer door. Take the old part with you so you can do a comparison and make sure you get the right part.
Jul 17, 2009 | Dryers
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Frigidaire dryer will not heat  runs/tumbles sometimes the heat works & sometimes it doesn't Mdl No. CRGR7900AS2
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 19, 2008 | Frigidaire GLER642A Electric Dryer
TUMBLE DRYER NO HEAT
Heating element
Thermal fuse
Wiring
Sep 16, 2008 | Tricity Bendix TM310W Electric Dryer
Dryer won't heat
Heating element
Thermal fuse
Wiring
Aug 11, 2008 | Kenmore 74832 Gas Dryer
Dryer runs, tumbles clothes, but does not heat
Heating element
Thermal fuse
Wiring
Aug 09, 2008 | Maytag SDG4606A Gas Dryer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
