Question about Hitachi Computers & Internet
Hitachi starboard 17TSXL very slow response to pen
I can write with pen on the tablet but it is very slow. If I attempt to write fast it falls behind. I am using PC XP.
I encountered a similar problem with SMART/Sympodium. There I solved it with resetting the circle of influence of the mouse. (Like how close to an icon center should you be for mouse/pen to be able to click on it).
But I do see a similar setting on Starboard.
Thanks
SOURCE: My Wacom Intuos3 tablet won't switch into pen mode
I had the same problem with my Intuos3 on Vista. Tech support suggested the following.
Do this.....Go to Start--->control panel---->system(in classic view)---->device manager--->click on "human interface devices"--->then click on "Wacom virtual HID driver" and right click on that and disable it. Your computer will ask you to restart and you will want to do that.
Everything works fine now.
Posted on Aug 14, 2008
The winning answer came courtesy of Mr Benedikt Schmitt of Wacom Europe, who offered the following solution: from the Windows Device Manager, disable the “Wacom Virtual Hid Driver” device. (Go to Control Panel > System and Maintenance > Device Manager, find the driver, right-click it and choose “Disable”.) One reboot later (welcome to Windows-land, circa 2008?), everything works as desired. Pressure and tilt sensitivity inside Photoshop still work, and the pen functions just fine in the rest of the Windows desktop. The absolute mapping makes it an absolute pleasure to point quickly and precisely. It makes my laser mouse feel rather clumsy navigating a large 24′ screen!
Posted on Mar 22, 2009
sonyscreens
  • 7 Answers
SOURCE: point pen fails after falls
I'm guessing something inside the pen was jarred. A basic solution would be to get a replacement.
Also try taking the tip out of the pen and leaving it OUT of the pen for 24hrs.
~Mitchell
Posted on Apr 26, 2009
bob_computer
  • 3153 Answers
SOURCE: The starboard does not connect to the computer
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Posted on Sep 18, 2009
aero26
  • 30 Answers
SOURCE: My Tablet pen wont release, it acts like im clicking and holding
I'm just gonna pass on a email from Tech Support I recieved.
"It sounds as though your pen has pressure in proximity. This is present when the tip sensor of your pen is stuck down causing the pen to think that it’s clicking before it’s even touching anything. What you may want to try would be to remove the nib from the tip end of the pen, it pulls straight out with a pair or tweezers or your teeth, and leave that out overnight with the pen left on its side. Place the nib back in the morning and if the issue persists then you may have a defective pen tip."
The rest consists of personal info and warranty advice so I'll leave it there.
Posted on Oct 13, 2009
I lost my starboard software cd
Software Download
Need to upgrade your software, or maybe you have misplaced your original disk. Click here and follow the procedure to request a downloadable version. You will need to have the serial number(s) of your product(s) to hand.
Software Download
Nov 04, 2014 | Hitachi StarBoard FX-77
Tablet slow response
Update the driver from the Wacom website. I sometimes have problems with that. Also try changing the setting from "Mouse" to "Pen" or fiddling with the speed settings. It could just be a problem with the acceleration setting.
Sep 30, 2013 | Wacom Computers & Internet
Windows 7 does not recognize Hitachi Starboard t-17sxl
Using the T-17sxlg on Windows 7 now. Did you ugrade the software to 9.33?
Jun 09, 2011 | Hitachi STARBOARD T-17SXL
Where do i find the serial number on my fx duo board
Take your cell phone and put it on it's camera setting. Then go to your Starboard and take a picture of the lower left of your Starboard (on the corner--facing the floor). That is where you will find the serial number. Look at the picture--there it is-the serial number!
Sep 09, 2010 | Hitachi StarBoard FX-77
Point pen fails after falls
~Mitchell
Apr 20, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
My tablet pen stopped working after a fall.
This is tricky ive dropped mine and it works perfectly, maybe it was too shaken tap the pen and the tablet a few times
Jan 06, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Pen only has one pressure thickness?
Hmm. . . Have you tried to install the driver for the tablet? If not, that should solve your pressure problem. I can't help with the left-click problem, however.
Sep 14, 2008 | Genius MousePen 8x6 (MOUSEPEN8X6)
Notepad 'floating' in the way
On the mac, it was an interaction with the 'Inkwell' handwriting recognition software. I turned that off in System Pref's. It may have actually only been the check box 'in any application' rather than completely off.
So Starboard works great now!
thanks
Aug 19, 2008 | Hitachi STARBOARD BT-1 FREEDOM TABLET...
StarBoard Fx-77 Pen does not write on the boards surface
i dont know why i bother looking on here, ive looked for a number of solutions for different problems and there is never any answers on here
Oct 18, 2007 | Hitachi StarBoard FX-77
Computers & Internet Logo
64 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
