Hello! Something wrong,probably,with key "Fn".When I need to print letters U,I,O,P,J,K,L,M I need press the key "Fn". If I do not press "Fn" I will get 4,5,6,-,1,2,3,0. Something is conversely.Unfortunately I lost my Backup disks. Thank you . My notebook is Aser Aspire 5100-3123
Ok in the keyboard there is fn right. Hold FN+Number lock (num lock) then it should transfer back to letters
Posted on Nov 29, 2010
  • 203 Answers
Check your settings for locality and keyboard settings.
i think you may have your keyboard in another language.
Posted on Feb 25, 2009
How to turn on numlk for gateway NE56R31u
You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
Feb 17, 2013 | Computers & Internet
What is the fn key
I suspect this is a message you're seeing on a notebook, computer or other device that has a keyboard. The "Fn" key is the "Function" key. When the "Fn" key pressed at the same time another key is pressed - in this case the F4 key, a different result will occur when compared to pressing the F4 alone. This works the same way as when you use the SHIFT key and a letter key - instead of a lower case letter, you get an upper case letter.
Typically, the keys on the keyboard are labeled in a light color. Keys that have a second purpose or function, will have a second label printed in a different color / slight smaller text or both. This label may be text or an icon or graphic. In order to invoke the second function of the F4 key, you will need to inspect the keyboard for the key that has is labeled with "Fn" text on it. Here's what a typical "Fn" key looks like:
The Fn key is in the lower left corner of this keyboard.
I hope this answered your quiestion and good luck!
Jan 04, 2013 | Epson Office Equipment & Supplies
I have fujitsu laptop runing win 7, when i type some letter be wrong for examle when i type m come 0 ,
Hello there,
Did you check the keypad for alternate keys.
For example net books, the number keys on the right side has an alter key on the some letters like the image below. when you accidentally press the [Fn] key, Numbers are written instead of letters..
Hopefully this helps. Thank you for posting..
Jul 12, 2011 | Computers & Internet
I have to press down on the blue key fn if not the letters type numbers and symbols
You need to press the "Fn" and "Num" keys. Holding the "Fn" key, press the "Num" key (also printed in blue, in most cases), the release both of them.
Mar 08, 2011 | Acer NSK8458AN Keyboard
My fn key is always on so cant type letters only the numbers that are assigned to that key!!!!!!(i have asus eee!!!!!
To solve this, simply press the Fn+Numlk
or depending of the model, press the button or Fn + Shift +Numlk
May 21, 2010 | Computers & Internet
Hello, Think Pad Keys don't show the right character when pressed. For example I press the letter O and I get a 3 out of it. Same when I press the 9 I get a B... What could have caused something so crazy...
Is there any function key that is lit (probably the F11.) You activated a combination of the Fn and a function key. If I guessed right (I have a Toshiba, not a ThinkPad) Fn +F11. Press Fn+F11 again, and the problem (?) will be solved.
Hope it helps.
Sep 29, 2009 | IBM ThinkPad A20 2628 Notebook
How to print screen
it probably is on the keyboard as small blue letters, which require that you hold the Fn key while pressing.
Don't forget to rate the advice!
http://www.aa1consulting.com
Jul 28, 2009 | Gateway T-6330U Notebook
Cannot use letters of my laptop unless use fn key but not capital
You need to press the NumLock key to get the keyboard to get back to alphanumeric - it has a symbol of a lock with a number 1 on it. A LED should also go out/icon in your tool tray should disappear as well.
Jul 05, 2009 | Acer NSK8458AN Keyboard
Fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
Mar 10, 2009 | Dell Inspiron 1501 Notebook
NC10: Can't type without holding function key down
I set up my girlfriends this morning, to turn off Num Lock, you need to have the machine on and select Fn + F11.
That'll turn it off and you'll have the bliss of typing normally again!!
Jan 06, 2009 | Samsung NC10-14GW Notebook
Computers & Internet Logo
434 people viewed this question
David Payne
David Payne
