Question about Dell Computers & Internet
Code 39 What if the registry does not come up. then what do you do and how do you get the registry to come up when you type regedit. when ever i do it pops up for about 1 sec and its gone. Please help
  • dom1100 Feb 25, 2009
    I tried in safe mode and it still didnt work. Same thing happens.
  • Dell Master
  • 13,433 Answers
Hey,
try starting up in safe mode, turn off the computer. then turn it on again, before the windows loading screen comes up keep tapping f8 so the advanced start up menu opens up, start in safe mode.
ones you are in safe mode, try opening regedit again.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 25, 2009
Wat does regedit means
regedit is an an inbuilt Microsoft Registry Editor. To start the regedit.exe go to Start>>>Run>>> type regedit and click OK. The Microsoft Registry Editor (regedit.exe) enables you to view, search for, and change settings in your system registry, which contains information about how your computer runs. Although you can use Registry Editor to inspect and modify the registry, doing so is not recommended, because making any incorrect changes can damage your operating system. Please go to http://en.wikipedia.org/wiki/Windows_Registry for more details.
Mar 22, 2012 | Acer Computers & Internet
Tip
How to fix cd/dvd rom error code 39
FOR WINDOWS VISTA & WINDOWS 7
1. Goto Start >All Programs. >Click Accessories, and then click Run.
2. Type regedit, and then click OK.
3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
4. In the right pane, delete UpperFilters & LowerFilters.
5. When you are prompted to confirm the deletion, click Yes > Exit Registry Editor > Restart the computer and issue is fixed
FOR WINDOWS XP
1. Goto Start and open RUN
2. Type regedit and hit the enter key to open it.
on Dec 05, 2009 | Computers & Internet
Tip
How to jump to a registry key directly ?
When you start Regedit, it automatically opens the last key that was viewed. (Registry Editor in Windows XP saves the last viewed registry key in a separate location). If you wish to jump to a particular registry key directly without navigating the paths manually, you may use any of these methods / tools.
Option 1 Using a VBScript: Copy these lines to a Notepad document as save as registry.vbs
'Launches Registry Editor with the chosen branch open automatically
'Author : Ramesh Srinivasan
'Website: http://windowsxp.mvps.org
Set WshShell = CreateObject("WScript.Shell")
Dim MyKey
MyKey = Inputbox("Type the Registry path")
MyKey = "My Computer\" & MyKey
WshShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Applets\Regedit\Lastkey",MyKey,"REG_SZ"
WshShell.Run "regedit", 1,True
Set WshShell = Nothing
Double-click Registry.vbs and then type the full registry path which you want to open. [ Example: HKEY_CLASSES_ROOT\.MP3 ]
Limitation: The above method does not help if Regedit is already open.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
TS-H653R - Error Code 10
To resolve this problem, remove the affected filter drivers. To do this, follow these steps: 1. Click Start , type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue .
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters , and then click Delete .
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters , and then click Delete .
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
1. Click Start vistastartbutton.jpg, type regedit in the Start Search box, and then click regedit in the Programs list.
securityshield.jpg If you are prompted for an administrator password or confirmation, type your password, or click Continue . 2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM. 3. In the right pane, right-click UpperFilters , and then click Delete . 4. Click Yes to confirm the removal of the UpperFilters registry entry. 5. In the right pane, right-click LowerFilters , and then click Delete . 6. Click Yes to confirm the removal of the LowerFilters registry entry. 7. Exit Registry Editor, and then restart the computer. 1. Click Start vistastartbutton.jpg, type regedit in the Start Search box, and then click regedit in the Programs list.
Sep 21, 2009 | HP Pavilion Elite e9180t PC - 3.00 GHz;...
Pioneer DVR-K17RS ATA ACER CODE=39
from your description, it's windows problem.
You can either reload your operating system or edit the windows registry.
To edit the windows registry follow this step from Microsoft:
http://support.microsoft.com/kb/314060
Oct 05, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)" . You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
3. In the right pane, right-click UpperFilters, and then click Delete.
5. In the right pane, right-click LowerFilters, and then click Delete.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Sep 24, 2008 | Acer (D10709-002) (D10709002) 802.11g/b...
Lost driver thro error code 39 dvd/cd rom drive
Dear sir/madam,
you can solve this by using the following links,
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
http://www.vistax64.com/vista-hardware-devices/113566-cd-dvd-rw-error-code-39-a.html
thank you,
Aug 23, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Driver problem
I also have the same problem my cd is working not DVD
Jul 08, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Dvd ram drive stopped working
to long winded to post the solution, click below for info http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Sep 01, 2007 | Abit SG-80 Motherboard
Computers & Internet Logo
Alun Cox
