Question about Inwells - RT-9292E8 - Two Way FM LCD Paging Car Alarm Security System With
I lost instrution for alarm raton alarm rt-9292b
I need istallation door lock, unlock with my alarm rt-9292b soo maybe you help me?
  • Anonymous Apr 18, 2009
    :( I have instruction
Peugeot 508 RXH: I cannot lock the car with the remote. The doors lock, but unlock again. The car detects open doors correctly. I can lock the doors with the dashboard button.
If you have 2 remotes does it do the same thing with both of them?
I/We have a Honda FRV and if you set the alarm from outside the car ....which locks the doors ...and the doors are opened from the inside, (yes I have set the alarm whilst still in the car,) this unlocks the doors as the drivers door has the master central locking switch on it. If I close the door withing a few seconds the alarm reactivates itself and the doors relock automatically
Presumably when your doors unlock the alarm is disarmed? Maybe your issue is linked to the receiver in the security system?
There is a difference, presumably, between you locking the doors from the dash as opposed to doing it from the remote control, the security system is not armed in the former, only the doors are locked +
Jul 19, 2015 | Peugeot Cars & Trucks
The alarm turns on when I put the key is in the door lock. Is there alarm reset?
Are you using an aftermarket key or the original? It may have a chip in it. Also if you have a spare original try it.
Jan 22, 2015 | 2009 Nissan Versa Hatchback
Avital alarm wont lock or unlock doors
If the remote is arming and disarming the alarm then, it should be locking and unlocking the doors as well. The door lock and unlock wires need to be connected. Are sure that they are connected? Do the door locks work with the switch?
Mar 03, 2014 | AviStart 5303 2-Way Security / Remote...
1999 VW bug wont start-suspect anti theft system. driver lock knob has a red light flashing. When key is turned to on lights illuminate but wont start. when passenger door is opened flasher come on what...
remove the key from the ignition and press the UNLOCK. its saying the alarm was triggered, eg if door was opened without first using the unlock on the remote. maybe when alarm was armed not all doors were fully closed. or you just reconnected the battery so the door was open without you ever pressing the unlock on the remote(which could be called DISARM the alarm)
Dec 19, 2017 | 1999 Volkswagen Beetle
I can't shut my alarm for my dodge stratus rt 2002, I don't have a remote control
If it is a factory alarm it can be disabled by locking and unlocking either the trunk or drivers door. if it is an aftermarket alarm (one installed after the car was purchased) you would have to get a new remote and get it programmed or take the car to a mechanic and have it removed
good luck
Jun 04, 2011 | Dodge Stratus Cars & Trucks
I have a 1997 Ford Expedition and the lock and alarm system is acting up. The driver?s door panel that will lock or unlock all the doors does not work. It will lock but not unlock the other door. The...
Check that you are enter the right code for open locks; for lock you dont need enter the personal code, just push the numbers pad. For unlock, you need the roght code, maybe you need reset and re-enter one new personal code.
Feb 11, 2010 | 1997 Ford Expedition
Codealarm keyfob on 2005 Mustang not locking/unlocking doors.
Try this g
Nov 20, 2009 | Code-Alarm Code Alarm Transponder
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Sep 11, 2009 | DEI Valet Keyless Entry System
Alarm system won't shut off
You might try locking all the doors from the inside and then closing them all. Then try unlocking the car with the key itself (NOT THE FOB) manualy. Try a combination of these things, like maybe locking it manualy with the key itself too. Usualy some sort of locking or unlocking manualy with the key will reset the system. Its almost luike proving to the car that you are who you say you are.
Dec 28, 2008 | 1993 Jeep Grand Wagoneer
Inwells - RT-9292E8 - Two Way FM LCD Paging Car Alarm Security System With Logo
360 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
Craig Butler
Craig Butler
xxxxxx xxx
Level 1 Expert
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
