Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Soap left in dispenser. dried soap on dishes and siverware
I've found that having the silverware holder on the pullout rack can cause an obstruction that won't let the dispenser door open. If the is a long knife for example on the left hand side. Putting the silverware holder on the door itself solved the problem immediately!
Posted on Feb 16, 2011
  • 117 Answers
After the fill cycle, check to make sure you have enough water in the dishwasher to wash effectively. You may need to have your fill valve replaced. You can test this by adding perhaps a liter of water to see if it makes a difference
Posted on Feb 25, 2009
Soap residue left on glasses after the wash is complete
A good quality rinse aid and forget economy mode its a waste . Also leave the dishwasher drying until it stops , it can be hard to hear but the LCD will still be on . also most plastics will be left with a soapy looking stain permanently .How much powder and use a goog quality one. another common problem is the soap dispenser being left open or coming open during the cycle.
check the drain hoses and the inlet tap is turned on enough
Cheers
Feb 05, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
Secondary soap dish won't open
i think you mean jet dry compartment.change dispenser. in some cases there is a kit but its better to replace new dispenser
Mar 02, 2010 | Dishwashers
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Our dish soap is not dispensing from the flip container.
sounds like you have a water circulaton issue, make sure your getting enough water in machine, and nothing is blocking the dispensor eform getting hit with the waster stream
Jan 11, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Soap foam left after dishes are washes. can't dry properly. and always has soapy water left in it and on the washed plates.
Try adding some liquid fabric softener to your dishwasher. This will reduce the foaming. Also make sure there is rinse agent in the proper dispenser, this will reduce the soap sticking to the dishes. Finally, reduce the amount of dishwasher powder or liquid you put in for each wash. If water remains in the bottom of the dishwasher, check if there is a filter or drain hose clogged. Is the dishwasher drain hose connected an undersink garbage disposer? If yes, make sure it is run periodically so it does not clog up.
Aug 09, 2008 | Dishwashers
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 04, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dispenser door
Remove the outer door panel and check the actuator for the soap dispenser door it is probably broken. You might also check and make sure you don't have an old soap build up inside the soap dispenser. Sometimes old soap builds up and dries inside the dispenser and causes the door to stick. It should be free. Good luck.
Dec 21, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
250 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
