Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
When I plug in ANY usb device, the computer freezes
And I have to turn it off at the switch to reset
  • tjkterrific Feb 27, 2009
    Thanks, Guys!
    I know I didn't give you much info but this sounds like something I've heard before.
    To answer your earlier questions, I check the Device Manager and everything looked good (at least the system said it was all good).
    Yes, it did it with the two USBs in front and even the ones in the back. The device I was trying to run when it started freezing was a simple Tekstor MP3 player. Later, when I tried to sync my Handspring Visor using the sync cradle (which I had run many times before), none of the USB ports would work at all.
    So I'll try what you've suggested. I did try ot update the BIOS, but I think it said my BIOS was current. But I didn't unplug everything, so we'll see.
    Thanks again.
    Tom
  • Chinmay patil
    Chinmay patil May 11, 2010
    Does this happen when you connect USB device to any USB port on your machine or a particular USB port ?
    also check if there any yellow exclamation marks next to the USB controllers in 'Device Manager' ?
    [rt-click on My Computer -> properties-> hardware-> device manager->
    click the + sign next to where it says 'universal serial bus
    controllers']
    Thanks
Disconnect all external devices except the keyboard, monitor, mouse and network.
download a bios update from the dell support site. Update the bios, allow it to reboot. After you reboot, go back to the dell support site and download the latest chipset drivers for your system.
After you reboot one last time, that should do the trick.
Posted on Feb 27, 2009
How to reset a gps golf buddy voice...it shows a symbol of a battery with an 'x' on...and wont charge or switch on ?
Hello
Turn off your device and plug a USB cable into your computer but not into your device
Hold the "Mark" Button
While still holding the "mark" button, plug the other end of the USB cable into your device
After you see a reset message on the screen, let go of the "Mark" button, and this should reset your device.
Jun 06, 2015 | GPS
The screen freezes on my Garvin nuvi 1300
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Best regards
Jul 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin 1390t freezes at loading maps
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Apr 30, 2010 | Garmin nuvi 1390T Car GPS Receiver
Sandisk mp3 freezes
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 04, 2010 | SanDisk Sansa e200 MP3 Player
Freezes on boot up at the SanDisk logo
From the sansa site:
STEP 1 – Reset the device
  1. Slide the Power switch up and hold it for approximately 20 seconds.
  2. Release the Power switch once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
If this article did not resolve your issue, please contact us at support@sansa.com.
Other possible solution.
Plug the unit in to the computer.
Even if it won't boot it might still recognize it as an external storage device.
If so, open My Computer and right click on the player. Select format from the menu that appears.
Select the FAT file system from the options that appear.
W A R N I N G!!!! This WILL erase all data on the device, please make sure you have a backup copy of your music and or other files BEFORE proceeding with this fix!! /W A R N I N G!!!!
Now, once you have the unit formatted, download the firmware for it from the sansa website at www.sansa.com.
Jun 28, 2009 | SanDisk Sansa e250 MP3 Player
Nascar Cisnet Laptop NCL3006 freezes after I plug in a USB device
sounds like a faulty USB driver - i recommend uninstalling all USB drivers and using drivermax.com to get the correct ones. Your computer may have automatically updated your drivers incorrectly without you knowing.
Hope i could help
CBZ
Comment if you need more assistance
Apr 28, 2009 | ZT Group Cisnet T2060 Notebook Computer
When i turn it on it freezes.
Hello, I own a TomTom also. I have listed the procedures from TomTom Home and hope this will work. First try a soft reset (Reset button is located at the bottom of the TomTom device next to where the DC plug plugs in). Make sure your batteries are fully charged up or the USB cord is plugged in.
If your device is not starting up properly, follow the steps below:
  1. Soft reset your device. *
  2. If your device still does not start up, then reinstall the TomTom application using HOME
If you have backed up your TomTom to your computer, then you can reinstall the TomTom application from your backed up data. *    In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. A reset does not delete any data.
Jan 16, 2009 | Tomtom ONE 3rd Edition GPS
My GoGear 8G wont come on
1. On you computer, ensure that Philips Device Manager is running.
2. Turn your mp3 player on (it should freeze at the Loading or GoGear Screen).
3. Plug in the mp3 player to your USB/Charger cable (ensure it is connected to the USB port on your computer), and then perform a soft reset (Power switch down and Volume up button simultaneously).
4. Let go of the other buttons as soon as the player resets. Hold the Volume down button until the player comes on. The player will be recognized by Philips Device Manager and will report a problem (and will allow you to repair it). Windows will also recognize it as a Mass Storage Device.
edit:
video: http://video.google.com/videoplay?do...56814975105076
Jan 15, 2009 | Philips GoGear SA5285/37 Digital Media...
Won't turn on at all
Press the reset switch on the back of the device. You will see it as a small hole near the bottom (a toothpick fits nicely for this)
Apr 20, 2008 | Samsung YP-T10 Digital Media Player
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
431 people viewed this question
Alun Cox
