Cannot open tray on DVD player. I put in the code that the book called for to unlock they tray but still nothing. I also took cover off the see if any connections were unplugged but all looked good. Power is coming on but when you push the open door button it says loading and then says no. Have any suggestions or should I just toss it? Thanks K
Same issue. When I press "Open" the unit stops spinning a moment, then "Load" flashes up on the display and it resumes spinning. I tried the code to lock or unlock the tray but the machine didn't acknowledge it. I'm about to pry it apart to rescue my DVD, then landfill it.
its because of the loosened tray belt.replace the tray belt to make it work properly.temperorarily use a pin .***** it under a small hole besides the eject button to release.thanks.
If the player is out warranty then remove the power cord and check if the are pin hole on player below or next the eject tray if there's one insert a paper pin or paper clip and tray will open abit and then gently pull the tray out and remove the dvd ,if this is not possible then you need open the side screws of the player and then gently remove the dvd as you get access to remove ,once done check with other disk if disk gets struck in the player ..
The DVD plays normally for 15-20 minutes and then it just stops as if the Stop button had been...
(More)
The DVD plays normally for 15-20 minutes and then it just stops as if the Stop button had been pushed. Occasionally, the screen breaks up as if the pixels are getting turned off and on.
I had a DVD player Toshiba SD 4000. The video output doesnt work, and Im watching the movies by...
(More)
I had a DVD player Toshiba SD 4000. The video output doesnt work, and Im watching the movies by another output, Yx is the name of the output. I went to see an electronic and he told me that was probably that my DVD lost it program, and that I need a number to fix it, but I dont have it. Now Im watching movies real bad, the image is distorsioned in some movies, sometimes when I put VCDs it works well, but not when I put DVDs. I change to free zone already (0) but still I have the same problem. If you could give me the code, or a place where to find it I will aprecciate, or if my DVD had another problem. Thakns for all.
