Question about ASUS P5V800-MX Motherboard
Cpu does not connected to monitor
Dear Fixya
I have a computer desktop & I have a problem that my computer does not working. my cpu is working but not appear in monitor. what is the problem..?
thank's
    Novelist:
    Scholar:
  • 72 Answers
I am guessing that you see lights on your computer, but no display on your monitor.
Have you tried another monitor? If you have and still no display, try unplugging everything from outside the computer except the monitor and then try again.
If no display, unplug power from computer and open the computer. Remove all expansion cards other than the video card. Disconnect all the cables from all of the drives, then connect power and try again.
Let me know if you need more help.
Honest1abe
Posted on Feb 25, 2009
When i supply power in my hp 1502 desktop and connect it with cpu than my desktop scree only show its going to sleep
1.check with a other monitor.
2.check the cabels should be seated tight.also the videocard should be seated tight.
3.the videocard or the monitor can be brooken check with a new or other monitor first.
Apr 17, 2013 | HP 1502 LCD Monitor
Acer aspire x1200 powers on but doesn't connect to monitor
  • Kindly check the cable that connect between cpu and monitor.
  • Re-insert RAM
  • Input Voltage if not connected using UPS.
Thank you for asking on fixya.com
Mar 20, 2013 | Acer Aspire X1200 Desktop PC - Athlon X2...
Beeping when turning on and monitor not working
Open the back cover of cpu cabinet.Then you can see motherboard reconnect RAM memory pci card or vga card if any.Make sure motherboard is not ground with cabinet cover.Then check if still same then try with another RAM memory then it should be work clean dust from all parts inside cpu also reconnect all connection to motherboard reconnect both connection to cd dvd rom and harddrive.Let me know if you need further assistance.Thanks for using FixYa.
Nov 20, 2011 | Dell OptiPlex GX280 PC Desktop
My desktop pc just beeps and the monitor does not do anything
Welcome to FixYa
Dear User,
First Re-seat your RAM ..check all cables connected properly inside CPU...Also let me know how much beep you heard .It is to provide a better solution..
Thanks for Connecting FixYa...
Dec 05, 2010 | HEWLETT-PACKARD Hewlett Packard Compaq...
Monitor Gets No Signal / Computer Won't Boot
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please unplug and replug the monitor cable that connects to the cpu. a loose connection/ bent broken pins of the connector itself usually causes such an error message to come up.
Nov 21, 2010 | Northgate (STAX2517C2) PC Desktop
No display...orange led on monitor.....
Thank you for using fixya, my name is Carlo.
You have two possible problems.
1. Monitor
2. Computer
Here's what you can do:
1. Unplug the cord which connects the monitor and the chassis or the CPU of your computer. It's the blue one.
2. Let the monitor to turn on even if it's not connected to the chassis or the CPU of your computer. If you can see their a box which is moving around the screen, then, your monitor is working fine. If none, then you should buy a new monitor.
3. If your monitor is working fine because you can see something on the screen after unplugging it from the CPU, then it's the CPU that has a problem on it.
If the monitor passes the test, then, the CPU needs some troubleshooting. Opening a chassis is not that hard but it still need some troubleshooting hands for you to do that. If you are not that techy, I suggest you get a technician to do that or any person who can do the troubleshooting.
Here's the troubleshooting that should be done.
1. Unplug the CPU the drain the power by pressing and holding the power button for 5-10 seconds.
2. Open the chassis. Then re seat the memory stick. Check if it works by turning it on, you have to connect the monitor while checking it.
3. If no go. Unplug, do the same with the hard drive, but most of the time, if the Led is orange, it's the memory that is not working fine.
Hope this helps.
For any questions, leave a message her. But if it helps, please rate and leave a comment and suggestion on how I am doing or on how I can improve my service.
Thank you for using fixya - your best online technical support site.
CARLO
var geo_Partner = 'cca8460f-a562-4792-a693-6fa0e7fcde78'; var geo_isCG = true;
Sep 27, 2010 | Computers & Internet
My monitor isn't working. I tried a different monitor, keyboard, mouse power plug on monitor. What else it there to do. When I had another monitor attached it it had no signal on the monitor. I know the...
For that open cpu cabinet
Reattach the RAM memory.
Open processor fan and processor reattach both.
Make sure motherboard circuit could not ground with cabinet.
Pull cmos cell from motherboard for 10 minutes .
Remove pci cards from motherboard if any.
Reattach VGA card if installed.
Then check.
Feb 16, 2010 | eMachines T5048 PC Desktop
L1932TQ Fails on Desktop, works on Notebook
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
Jul 12, 2009 | LG L1932TQ LCD Monitor
The problem is with the monitor on my used by my wife, connected to her PCU. Tonight as she was using it, the monitor, a Acer AL1913b LCD Monitor, flat screen, went black. My computer, across the room...
There is only one way to check it out.... or to find out that where is the problem
in monitor or in cpu......
Solu: Plug another monitor to your cpu... if the other monitor works that men problem in your monitor else problem is with the cpu....
Good Luck!!
Please do rating...
Mar 25, 2009 | Computers & Internet
Before we moved to a new house my samsung syncmaster 710v monitor was working fine but when I reconnected monitor to the cpu, no picture appears but green power led flashes and when i disconnect the...
First make sure all cables are tight and secured, and try pressing the Auto Button on your Syncmaster? It's for auto configuration.
If problem persist and if possible can you try using another known normal monitor/LCD? Also try your monitor using another cpu or laptop.
May 12, 2008 | Computers & Internet
ASUS P5V800-MX Motherboard Logo
50 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
