Question about Canon PowerShot SD600 Digital Camera
Taking outdoor pics of people when its sunny.
Are there settings where I can take pictures without the harsh facial shadows? I sometimes have to take pictures in the shade.Sometimes it is hard taking pics when it is sunny.Any advice or tips?
    New Friend:
  • 30 Answers
As cameras become more and more automatic, it is harder for thier owners to be 'photographers'. I was trained as a photographer many many years ago on large format, film cameras with no meters and digital was something for the science fiction books. I rarely put any of my digital SLRs in one of the automatic mode.
With your SD600, you have very little control that you can use to overcome this issue. but you DO have some...
First trick is to manually turn your flash on, even in bright sun when shooting outdoors, (this will do two things, turn on the flash which will provide some fill light on the faces of your subjects to reduce the range between the darkest and lightest areas on your people subjects; and it will change the length of time that the shutter stays open to compensate for the slowness of the flash. So you are puttting more light on thier faces and allowing light to pass thru the lens for a longer duration.)
Second, wear a white shirt/blouse. your subjects are in bright sunlight, but the faces are dark - tells me the sun is behind them and in front of you. Thus a white shirt will reflect light and you become a reflector of sorts (this is a short range trick only) Be mindful of the color of your shirts here, color also reflects and may cause their skin tones to become slightly 'off'.
Also try to get your subjects to step into a shady area so that there is not such a high range difference between the brightly lit areas and shadows on them, some cameras, yours included can only do so much -
Look at it this way, I can ask you to someone to swallow a grape in one bite, maybe something the size of a lemon is possible, but you cannot take an entire potatoe into your mouth at one time. In the same way, your camera can only take in a given 'range' of values (intensity) from the darkest to lightest before you exceed it's ability. anything brighter than a given level is simply blown out and anything darker than a given value simply records as black or dark with little or no detail.
This is why a lower pixel count SLR takes better pictures than a high pixel compact camera. Most folks only read the pixel count and go 'ooh ah' - because that is how cameras are marketed. (lots of points recording lower quality range vs fewer points recording higher quality range)
Find ways to stay within the range that your camera can accept. add light to the low end as in tips one and two or reduce the high end, as in tip 3)
Let me know how it works out...
Posted on Jan 28, 2010
SOURCE:
Hello from Bulgaria :) can you tell me the settings for optimal quality of taking pic with samsung S730? because sometimes when i change it to manual or ASR the picture quality is awfulll... thanks
That depends on the subject matter and, more importantly, on what YOU want the picture to say. Usually for landscapes you'd want a deep depth of field while for portraits you'd want a narrow depth of field. You wouldn't want a picture taken outdoors on a sunny day to have the same mood as a picture taken at night. That's why there are so many settings. If there was such a thing as optimal settings for all pictures, we might not need anything other than on/off switch and the shutter release button.
Again, YOU must decide the settings (even if it's only to hand control over to the camera in one of the automatic modes). You and I could be taking pictures of the same thing at the same time using the same type camera, and there's a good chance we'd be using different settings. It's not that one set of settings is better or worse than the other.
May 26, 2011 | Samsung Digimax S730 Digital Camera
When taking pics my camera pic are a white blur how do i fix it?
Back up from what you are photographing, and turn your flash off or onto auto. You do this by lightly tapping the little Lightening bolt in the lower right corner of the LCD screen and repeat as necessary until the yellow lightning bolt on the left side of the screen either has a red circle on it w/ a light through it (off) or a capitol A beside it (auto). I prefer auto, because I take most of my photos outdoors and it's hard to tell if a flash is necessary under a tree when its really sunny, or on a really cloudy day @ the beach...(sunny day in the shade-flash. Cloudy &rainy beach? No flash, not ever!) There is a problem w/ the cameras flash system though, you can set it on auto thinking that you can just click away & let the camera handle the flash like you can on most cameras, but the Vivitar almost always has to have the flash reset after every single photo, but then every once in a while it stays on the same setting all day long!
Jul 11, 2010 | Vivitar ViviCam T328 Digital Camera
Yashica ez digital 6032- 6 mp camera.. i got one sparingly used yashica camera... with above spec... which shows trouble when taking stil pictures outdoors... indoor pictures and video indoors n outdoors...
i am using yashica ez digital 6032 camera but while using SD card of 4GB memory, it is not working. it is asking to format. Pl. help me regarding this problem. Shall i format the camera?
Apr 27, 2010 | Cameras
Dark semi circle shadow and pics too bright
Are you using a lens hood? Is your ISO set too high?
Apr 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
Outdoor pictures is not working..
I'm not familiar with the A430 specifically, but all digital cameras have exposure settings for the type of picture you're taking (outdoor scene, portrait, shadows, etc.). Since you can take good interior pictures, I think you're likely set on a "indoor" or "shadow" setting rather than "auto". Some of the icons are a little confusing but "auto" is the best setting for most situations. If the camera is set to auto already, then I would suspect that the light sensor is defective and contacting Canon Support is your best option.
Aug 13, 2009 | Canon PowerShot A430 Digital Camera
Blackberry Pearl - camera stopped taking decent pics
You checked to see if the Color option is set to negative. Either that or the camera is ddead on the phone. Sorry.
If you updated the os on this phone to 4.5 they have been seeing issues with this problem happening on pearls using 4.5.
Dec 31, 2008 | RIM BlackBerry Pearl 8100
There is a long delay taking pictures
Check to see if the self-timer is on. You can set the timer to 0, 2, or 10 sec. A 2 sec. delay will help to prevent blurry pictures. But setting the self-timer to 0 will take the picture as soon as you push the button.
May 26, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Casio Exilim s500--horizontal lines in picture and autofocus creates blurry pics
It appears this problem is due a failing CCD device in many brand cameras. All the manufactures use the same source(s). I have not persued Casio as yet, but other companies are offering a recall to replace the CCD for free. I plan to use this approach with Casio. Search the web for "failing CCD in digital camera", it describes exactly what we are observing.
Dec 02, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Using Flash Outdoors
For portraits when the sun is high, a fill-flash is certainly appropriate. Had you not used your flash on this, the sun would have cast long shaddows under her eyes and nose and chin, which can be very unflattering. I like the image you captured! One other option for you, when you have control over your subject and the shooting conditions, is to move your subject to a shady spot. Here the lighting is not so harsh and more of the facial features are seen. This adds character and softens the overall look of your portrait. But even in these shady situations, it's not a bad idea to take a few using the fill flash too, bracketing your shots this way will increase the likelihood that you get a "keeper."
Sep 11, 2005 | Olympus Camedia C-4040 Zoom Digital Camera
Canon PowerShot SD600 Digital Camera Logo
88 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
