Question about Kenmore 22642 Top Load Washer
Kenmore washer...the water just runs it never fills up.
I have a kenmore top load washer model number 110-22642100. when the cycle is selected the water just runs. The basin/tub never fills up. it just stays in the section and never fills up. the water drains out but does not fills. if i switch to spin it will spin.
  • 1 more comment
  • Anonymous Apr 29, 2009
    water runs and washer never fills up
  • Anonymous Mar 20, 2014
    Kenmore washer leaks water through drain hose as tub tries to fill up
    Kenmore washer model 11092575110 leaks water through drain hose as tub tries to fill up
  • 5,911 Answers
I have seen this problem numerous times on service calls. It sounds like you have a siphoning problem. The key symptom is the wash tub that continously attempts to fill, but cannot achieve the proper water level. This is often caused by not having an air gap on your drain line, improper placement of the drain hose, or a standpipe that is too small in diameter. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If you place the drain hose in the standpipe too far, or seal the top of the standpipe, this can cause a vacuum which will cause the symptoms you describe. A tell-tale sign will be a sucking noise as you pull the drain hose from the standpipe. Read through the link I provided. If this does not correct your problem please post back and let me know before you rate this solution. This way I can try to assist you further. I hope this corrects your problem.
Posted on Feb 25, 2009
  • 1 more comment
  • lhensley11
    lhensley11 Sep 14, 2012
    Thank you so much...It was the drain hose...You just saved me a repairman bill and I appreciate it very much.....
  • redwolf94_98
    redwolf94_98 Oct 16, 2012
    Thank you as well, same issue and your answer was correct.
  • Gary Lindquist
    Gary Lindquist Feb 15, 2014
    Thank you so much, I was getting so frustrated with this that I was about to go out and get a new washer. You saved me hundreds! Thanks again!
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Does not fill
Check the solenoids at the water inlet valve for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty solenoid.
Hope this helped and best wishes.
Aug 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore will not agitate
The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Model 110.26712693 stuck on agitator cycle
Your air pressure hose going to the water level switch is pinched.
Open the top control panel to access the clear plastic tube and relieve the pinched area.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Pf and of codes comming up on screen
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Washer is filling and filling and filling...
CHECK YOU WATER LEVEL SWITCH IT SOUNDS LIKE IT IS STUCK ON THE FILL CYCLE
Jan 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22642 Top Load Washer Logo
711 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
