Question about HP Photosmart 2610 All-In-One InkJet Printer
Cannot reinstall Have tried cd, from control panel and tried to download from internet. Nothing works. I can print and do things some things with just not on my computer
  • Thomas F. Schneider May 11, 2010
    So, what exact does it do? Goes through the motions? Does no movement? No lights?
  • 408 Answers
I had a friend that had this problem.  Disconnect the printer and shut it off.  Go to add/remove programs and remove all software related with it.  Restart your computer.  Put the cd in the drive and install all the software.  DO NOT connect the printer until the software tells you to or says that it can not find the printer.  First plug the USB to the printer and to your computer.  Then press the power button on the printer.  If a found new hardware box pops up, press cancel.  Continue with installing the software.  Restart your computer when you are done.  This worked for my friend.  People do make the common mistake of not unplugging the printer when reinstalling software.  Hope it helps.
Posted on Mar 02, 2009
When I tell the PC to print it accepts the message, the little printer shows in the task bar and then it dissappears...no response from printer at all. I have checked the cords & rebooted my PC but...
I have this problem with my HP as well. Turn your printer off for a few minutes then back on. Try printing again, if the same thing happens you will need to uninstall the printer software and reinstall it. You will do this by going to start, control panel, change or remove programs and a list will generate. In this list look for your hp printer to be listed, highlight it and click remove. Once it is removed you will need to reinstall, do this by either placing your cd in and following the steps or if you dont have your cd, log onto www.hp.com and click drivers and downloads, select your model or if your printer is plugged in it will auto detect for you. download and install and attempt to print again, this should work.
Oct 08, 2010 | HP Computers & Internet
Lexmark z2400 will not print, the comuter says document is pending. All connections are correct. Do I have to uninstall the printer, and reinstall with the CD? I rebooted the printer, and nothing. It is...
I am assuming you have it connected via USB to your computer. If you have an additional USB port on your computer then try powering off the printer, attach the USB connection to a new USB port, go to the Control Panel (Start, Settings Control Panel), go to Administrative Tools, go to Services, scroll down to Printer Spool, stop the service, start the service, and power on printer. Try to print a test page. If it fails, power off the printer and delete the print driver. Reinstall the driver using the CD.
Aug 30, 2010 | Lexmark Office Equipment & Supplies
Hello!After reinstalling WindowsXP on my computer (Had problems with viruses) can not connect to the Internet. O2 Installation CD says FAILED NETWORK ADAPTER. When selecting Control Panel and then Network...
I would check out the Internet for the updated driver for the NIC in the suspect machine, download it on another machice, copy over with flash disk. Remove the driver, install the new driver, **** down, reboot. If there is nothing physically wrong with the machine and you just re-installed the OS, sounds like you have a corrupted device driver for you NIC.
Sep 19, 2009 | Computers & Internet
Quattro Pro X3 Refuses to print in anything by Best Quality mode
document contains some control characters that prevent you doing so
Mar 23, 2017 | Computers & Internet
Laserjet 1020 with mac osx
Ok, you may want to consider re-installing the printer driver or in any case download updated printer drivers. Just don't forget to reboot after installing:)
Oct 16, 2008 | HP LaserJet 1020 Printer
Lexmark X2500 All In One did not come with an installation CD. The only thing the printer will do is print. How can I purchase a CD for installation?
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,find the file,doubleclick on the file, if you get introubles ,then followinstructions below to reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista
Oct 04, 2008 | Lexmark Office Equipment & Supplies
Problem installing lexmark 2650 on toshiba a 30 satellite
did you add a printer onto the computer control panel
did you down load the printer driver from the manufacturers web page downloads
Jun 03, 2017 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Printing problem
To delete the file from printer cue, unplug printer, restart computer with printer unplugged, and delete file.
If it still does not work after deleting files, reinstall all printer software using software CD provided with the printer.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Download driver from website, or use the disk and run the install file.
Sep 12, 2008 | Lexmark X4550 InkJet Printer
HP psc 2110 all-in-one wont print from internet
I'm assuming you went to the HP site and downloaded the Vista drivers??? Other than that try this:
  1. From Control Panel > printers... uninstall all printers.
  2. Unplug USB cable to printer and re-boot.
  3. Install Software.
  4. Plug USB cable back in.
Hope that fixes Ya...
Geno
Mar 26, 2008 | HP PSC 2110 Color Printer
Compaq A3000 All In One
Have you tried reinstalling the driver?
Jun 13, 2007 | Compaq A3000 All-In-One InkJet Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
