Question about RCA HD61LPW42 61" Rear Projection HDTV
TV has alittle dark haze,not bad,9inchs in from side,top to Bott
My RCA HDTV - 61 inch has been working fine,only replaced the lamp bulb only 1 time, My tv is still fine, but it has a dark haze on one side
about 9 inches in from top to bottom,not bad,like it was a glare or shadow
.....looking at TV on right side
  • 1 more comment
  • jt9565 Mar 16, 2009
    My tv looks like there's something hanging down inside the box itself, getting in the way of the picture in the upper left hand corner of the screen. It doesn't block the picture, it just looks like a shadow on the screen. I'm thinking it's a liner from the top of the box itself or a wire in the projection area, perhaps between the lamp and the mirrors? I'm thinking of taking the thing apart to take a look.
  • Anonymous Mar 30, 2009
    I also have the same exact problem, I took the entire unit apart today cleaned everything but still have a square edge shadow on the upper left side of the picture. I am now trying to locate a color wheel, which is extremely noisy, pulled the colore wheel apart oiled the motor and it only reduced the noise marginally. The issue is the bearings are bad because of an unbalanced color wheel disk, which appears to glued together.... hihi
  • sue2in2000 Apr 08, 2009
    My dark haze is on the right side, from top to bottom. Not sure when it started because at first I thought it was glare from the window. The lamp was replaced once a while ago. There is no noise anymore. Would love to get rid of this shadow!
    Problem Solver:
  • 5 Answers
Probably the light tunnel. The tunnel is a square tube made up of 4 mirrors glued together.
It looks like this from the side: |_| (with a piece on top too.)
When the glue breaks down, it shifts inside the little mirror holder. The shifted mirrors looks like this /_/ what you are seeing is the shadow of the tilted mirror tunnel.
ON the RCA's there's not a good fix.
RCA's response:
"Ok, well sadly they do not offer the light tunnel anymore, which is what you need. Sadly you would be rendered to get a whole new light engine assembly. That would be the D.N.D module, light tunnel,color wheel,optic spanner, and oci. mirror. Your best bet would be to search ebayTV has alittle dark haze,not bad,9inchs in from si - 2_bing.gif for a broken engine and replace it that ways."
That is the ONLY response I got from them.
I took the set apart and found the 4 tiny mirrors. I will be attempting to epoxy them together. (The set is dead anyway, why not try?)
Posted on Mar 22, 2010
I have a samsung hl-s6187w 61 inch and it keep shutting off.. the screen goes black but i still have sound for about 5 sec then shuts off.. can anyone tell me what the problem is?
I doubt it's the color wheel. When our wheel went bad the TV didn't come on at all. It could be the lamp. Try reseating it first. That fixed a problem the first time for us. Later we had to replace the lamp because the TV was getting dark. It could also be your ballast, but we've never had to change that. I'd start with the lamp.
Feb 16, 2015 | Samsung HL-S6187W 61 in. HDTV
How do i install a lamp for a RCA 61 inch HDTV, have the back cover of t.v. but cannot locate lamp. Thank You
you found a part number for a lamp for your RCA DLP TV . it should be on the back of the unit there is a access panel . it is near the light engine . . do you have a MODEL number off of the back of the set . . and do you just have a bare bulb or one with the housing complete ? THE SAD PART IS WITH OUT A MODLE NUMBER A 61 INCH RCA is a wide range of production sets so its impossible to give you a correct answer with out this information
Jan 04, 2015 | RCA Televison & Video
How do i install a lamp for a RCA 61 inch HDTV, have the back cover off but cannot locate lamp. Thank You
I am not sure about the RCA but on th Panasonic models the lamp is actually loaded from the front. Check the front panel just below the screen
Jan 04, 2015 | RCA R61WH76 61" HDTV
MUST READ THIS I have a rca 61" hdtv purchased in 2004 with a 5 year extended warranty (thankfully) and have had nothing but problems with it. it is the worst thing i have ever bought.exactly 13 months...
All DLP TVS are lemons really.Most the Convergence ICS,they use on the board held the picture together will alway die about 1 year or 1 1/2 year all way need it replace.The bulb have life spans but never reaches alway dies before than.
Apr 01, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
I have a 52 inch RCA DLP t.v. I have replaced the bulb but the picture is very dark. Has the light engine failed?
Chances are YES! Call Encompass Electronics for Price and if they have any in stock or visit on their website 1-800-638-3328 You can call UED is another outlet 1-800-648-6657
Oct 05, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA HD61LPW42 61" Rear Projection HDTV Logo
213 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
