Tv clicks, picture distorted have a phillips tube tv 29"
  • 790 Answers
Hi
What you mean?
Thanks!
Posted on Feb 25, 2009
Multimedia projection tv distorted picture
IF IT'S A 3 TUBE PROJECTION TV, THEN THE COVERANGE IC'S CHIPS BAD
Jun 26, 2014 | Televison & Video
I have a 60" rear projection tv and the picture looks like its missing a color the picture isnt distorted or anything but the colors are bad what could be the cause and the fix
sounds like a Phillips or magnavox that has bad CRT coolant which needs replacement. If so you can get the Phillips CRT coolant repair kit from www.tvrepairworld.com it comes with instructions and the coolant for all three CRts,
Mar 01, 2013 | Televison & Video
Panasonic 29 crt tv problems with the geometry
If there is a picture geometry problem, you have to check its Pin Amp section circuit inside the circuit board for any damaged component/s. If this section have any fault, the picture geometry will be distorted. Before adjusting the picture geometry after entering its service mode settings, you have to check this section first. If you want to know how to enter the service mode option window to this set, check this link.
Jan 27, 2013 | Panasonic TC-29P22R 29" TV
Our Phillips HD projection tv has lost a picture. It started by blacking out once in a while but now the picture is constantly rolling. The screen is distorted and it's impossible to even recognize what is...
Cloudy,distorted pictures.The tv have R,B,G CRT tubes gun coolant probblem.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced.
Sep 11, 2010 | Philips 55PW9363 55" Rear Projection...
Slow to turn on Phillips flat screen tube big screen
That is a common issue with the last generation of the phillips big screens, the best answer for this is one that i got at a meeting with phillips service several years ago. On philips the tv will not show a picture till the tubes are balanced out, simular to sony, but in a phillips if the white balance is not correct the picture and sound will be muted till all three tubes have warmed up enough to produce a good white balance. As the set ages the tubes become weaker and this procesess takes longer.
May 07, 2010 | Philips 43PP9202 43" Rear Projection...
I'm having a problem with the color green being distorted on my TV. Is this a color tube issue, bulb issue, lamp issue?
This is a picture tube type TV. No lamp.
You don't describe the distortion.
A colour green picture that is twisted and shifted away from the other colours is a convergence problem. see Projection TV Convergence on this site.
If the green is smeared, out of focus, larger than the other colours like a halo around objects, things like that, it is the green picture tube. Sony has discontinued most of the picture tubes so you may not be able to get this fixed.
Mar 31, 2010 | Sony KP-46WT520 46" Rear Projection...
Hi I have a hitachi 50 inch projection tv and
there is no tube in a projection tv it will be the conversion chips if picture colours aer distorted
Dec 12, 2009 | Hitachi 51F59 51" HDTV Projection...
Ive got a 29'' tube flatscreen that wont work no more
seems to be an issue with picture tube.Please try after changing picture tube
Jul 28, 2009 | Televison & Video
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Televison & Video Logo
221 people viewed this question
Top Televison & Video Experts
Electro Med Services...
