Question about Amana 3.2 cu. ft. Top-Load Washer
Water leaking on bottom center of tub when water is in it im wondering should i fix on buy a new one i the shaft is pitted
    Genius:
  • 1,075 Answers
You dont say how old the machine is??.but you could be right.But my main suspect would be the seal infact i think there might be two{ inside/outside} but i would say the problem is in this area.by the time everything is added up it might be cheaper to replace the machine.hope this helps.adrian
Posted on Feb 25, 2009
My Maytag A9700 is leaking from the bottom of the outer tub. I have changed both the tub bearing and the stem seal but it is still leaking - even more than before I started. My question is whether I
If the boot seal was properly seated onto the outer tub lip, then you should focus on the water seal (#39 in the graphic - it should have come with the mounting stem kit) as the source of the leak. Extra care must be used when installing this over the agitator drive shaft - some recommend adding a lubricant (Maytag center seal grease works well) to the shaft before sliding the mounting stem (and water seal) down onto the agitator shaft. Also, check the two sealing surfaces where the top of the boot seal (#40) meets the bottom of the mounting stem (#30). Look for cracks, chips or any bits of debris. Anything that keeps those two surfaces from meeting perfectly will cause a leak. These repairs should go fairly smoothly, but leaking water seals and chipped boot seals can cause problems.
Dec 06, 2014 | Maytag Washing Machines
The washer is leaking from the bottom
Your center seal is going bad or you have a bad hose, leaking water pump, or a cracked tub but GE is notorious for there center tub seals to going bad I would recommend a qualified service technician come look at it to rule out which one it is if your centers tub seal is bad I would buy a new washer but sorry for the troubles.
Jan 22, 2011 | GE WBSE2090A Top Load Washer
WATER LEAKING FROM ABOVE THE WHAT APPEARS TO BE THE TRANSMISSION IN THE CENTER OF THE MACHINE
Your center seal where the shaft goes through the tub to the transmission is bad and is letting water leak bye it. I would not repair the machine it will run you $350 to $600 to fix you have to buy a bearing kit which has the seal in it and the labor involved is a lot normally 4-5 hours to complete the job I would not attempt this on my own unless you know what your doing. I would start looking for a good quality used one or a new one sorry for the trouble hope this helps.
Jan 07, 2011 | Maytag SAV2655A Top Load Washer
Leaking from the bottom of the washer.
it sounds as if the main tub ring is bad you need to pull your agitator out and check the two blots that hold the tub to the shaft and make sure they have not become loose or broken causing the inner tub to drop on the shaft and tear the tub seal.
Feb 23, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Leaking water from bottom of tub during filling, around center shaft.
your outter tub seal is leaking between the drum and transmission might want to have a repairman tackle that job
Jan 17, 2010 | Maytag PAV2300 Top Load Washer
I have a maytag washing machine, model #LAT9406AAE, water leaking from the bottom of the tank where the transmission housing shaft is hooked up.
That sounds like the center shaft seals are worn out. If the shaft and related parts are not corroded or rusted, it can be fixed. If it is the tub boot seal, it is a major teardown either way. But that model is worth fixing up if it is in good enough condition, and the cost in your area isn't over $200.
Jan 06, 2010 | Maytag Washing Machines
GE WBXR2060V1WW leak_transmission shaft and tub
The tub seal is leaking, often this damages the transmission. A new tub seal comes with the transmission this page should help http://www.appliance-repair-it.com/GE-washer-disassembly.html
Nov 12, 2008 | GE WDSR2080D Top Load Washer
Leaking washer
remove 2 screws bottom front panel pull panel down should drop and can be pulled out of way ckd area around pump also around center shaft where it goes through bottom of tub lest likely hole in tub make sure small hose back left is attached to small connector on side of tub
Jul 10, 2008 | Washing Machines
Maytag Dishwasher-pdb2430awx-Leaking
I believe that you must buy the plastic pump housing.....And that vinyl type shaft seal comes with that..I think!!!!
I have the same problem.....I changed the regular seal kit at a cost of $30.00 CND....Which is like what? 100.00 American.
Anyways mine still leaks after all that. Turns out there is so much rust between the nylon seal that is attached to the motor shaft, that water works its way down there. Funny that seal does not come with the common seal replacement kit. Im going to check tomorrow to see If I can get that seal alone. My concern is that after I drive for another hour one way to get that seal. Am I only going to put it on just to find out that the shaft is pitted to much by the rust to seal again? I am so tired of buyin ****!!!!!!
May 22, 2008 | Dishwashers
Spins really fast and loud and is leaking at bottom of tub where shaft goes in
buy a new washer .specifically a direct drive whirlpool,no belt. maytag washers are not what they use to be.
Jan 04, 2008 | Maytag Legacy Series Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
