Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker microwave JVM1640wb004. During the ice storm we lost power for 6 days was heating the room with gas range. also used stove to boil water. when power came on all appliances except this one worked. Have changed the fuse but still nothing. Help
5 Suggested Answers
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 95 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 8872 Answers
SOURCE: GE spacemaker microwave model #JVM1650SH
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 10, 2008
MicrowaveSvc
  • 8872 Answers
SOURCE: microwave broken door latch
The door latch head (hook) is pretty easy to replace or repair if that's the issue.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Sep 27, 2008
MicrowaveSvc
  • 8872 Answers
SOURCE: I have a GE JVM240 spacemaker microwave oven. When
Actually, you should always use the hood vent exhaust fan when you're cooking on the stovetop, but I don't think that caused this problem, although it's possible.
Instead I would most strongly suspect a shorted high voltage rectifier diode, which is a pretty easy fix.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Mar 06, 2009
GE Profile microwave # nm1851dm2bb lost all power while heating something. Could it be the internal fuse? Anything else?
If you're lucky it's the internal fuse. Otherwise, there's not much other stuff besides the fan that's easily replaced.
Nov 25, 2013 | GE Profile Spacemaker Over-the-Range...
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Ge oven membrane panel
Order GE range/stove/oven parts today. We ship GE range/stove/oven parts on time or your order is free. Return any GE range/stove/oven part for any reason for one full year. Customer service for GE range/stove/oven parts is available 7 days a week. More than one million parts available. We stock the GE range/stove/oven parts you need for immediate shipment. We have more than 200,000 high-resolution part photos.
Jul 26, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shut off like it lost power but the receptacle does have power to it. My model is an LVM1750.
The thermal cut out switch in the cavity is bad. I was unable to locate a wiring diagram on the internet but when I took the microwave apart, I found the wiring diagram inside the microwave on the back side of the touch panel.
This unit is mounted above the stove. We were cooking on the stove and also in the microwave. I think there was enough heat to trip the TCO switch.
Nov 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
JVM1850BH02 Microwave completely shut down, not working after...
The extreme heat has opened up one of the thermostats / thermal cutouts (TCOs) in the oven.
If it was the bottom TCO or magnetron TCO, you should be able to access them by just removing the control panel.
But if it's the one on top of the cavity, the oven will have to come out of the wall, then you need to pull of the outer cover..
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You should locate and look this over first.
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Jun 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No power...
If the stove was on without the hood fan's being on, it could have put too much heat in the "innards" of the microwave. It may have opened the thermostat or thermal fuse located inside - either on the chassis of the microwave or or the magnetron. It will look something like the one in the attached photo. For helpful exploded view diagrams and to order any needed parts, you can visit the GE parts Web site or the Sears parts Web site at http://www.geappliances.com/shop/prts/ or http://www3.sears.com/ (the 3 is correct) In my profile, you can find a link to my site, where you can find critical safety & disassembly tips. Post back if you need more help.
Dec 23, 2006 | GE JVM1660 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
145 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
