Question about Insignia 19 in. Widescreen Flat-Panel LCD HDTV
VG4 mode on Insignia 19" widescreen LCD wont accept computer
Ive tried hooking up my new Insignia to my computer to be able to use it as both my computer monitor and a TV. It has the hook ups in the back for it but every time i get everything together it says Mode Not Supported. I dont have the manual, so is there anything i can do to get it to work? a new cord? or something i need to do on the TV?
  • bribl Mar 21, 2009
    i have the same problem! It is killing me.
Go to your control panel of your computer (using a different monitor obviously) and change your screen resolution to 640x480, 800x600, 1024x768, or 1440x900. any of those resolutions should work. also go to advanced and make sure it is set at 60 herz.
Posted on Mar 21, 2009
Is Magnavox DVD and playstation 2 compatible to insignia tv
well you need to change the input on the tv for them to work
Mar 02, 2015 | Insignia Televison & Video
Samsung TV will only work as PC Monitor. AV/S-Video/Antenna doesnt work
is your antenna hooked up correctly and do you have all the cords hooked up and have you tried to make sure nothing has gone out on it
Nov 11, 2013 | Samsung Televison & Video
What is the "digital output" for on my hd tv? it has a square cap and when I pull the cap off, it seems like all thats in the is a red light. what is it for? Side note- Im trying to hook my older hp...
I believe it is for Sony Devices Digital Output. You should be able to hook up your TV via High Def or using a Monitor cable. Your laptop should recognize this as a second monitor and you can choose to mirror or extend your display in control panel. You can also select your default audio output as the TV while its attached. Hope that helps.
Oct 13, 2013 | Insignia Televison & Video
Hp w1907 VGA no input signal
its is telling you the truth (99.9999999% of the time)
believe it !
no PC stated
no TV model stated nor clear connections stated.
are you trying to get the PC (the tower means that)?
to run to video concurrent ports at the same time?
so do both fail,
VGA side
and DVI side,
you never said.
hard to help lacking
what TV
what Tower
what connections, and special adapter (HDMI)
the TV has DVI??
sorry, cant see what you have there. at all.
Feb 01, 2018 | HP w1907 LCD Monitor
My USB Ports on the monitor have stopped working
Try replacing the usb cable from the monitor to the computer with a new one or make sure that the cable is connected.
Feb 14, 2018 | Dell SP2009W 20 in. TV
I have a dell precision m60 and I want to hook it up to my hitachi 55 plasma tv Ive tried to do this via s-video without success
Trying to hook up your computer to the tv? Or the monitor to the tv? Anyways, you can't hook up the monitor to the tv to see the same thing on both. But for the computer to the tv, connect the s-video cable to the tv from the computer, and you have to press (on the computer) ctrl+alt+F2 or ctrl+alt+F1 it's different for some computers. But if that's what you tried to do, that's the way you do it.
Anyways, hope this helps.
Jul 14, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
How to hook up flat screen monitor??
The new flat screens hook up the same as the old CRT monitors.
May 03, 2009 | Televison & Video
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
May 20, 2008 | Televison & Video
Insignia 19 in. Widescreen Flat-Panel LCD HDTV Logo
550 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
