Question about Janome Hello Kitty 11706 Mechanical Sewing Machine
Excess thread on back side of fabric
I don't know how to explain the problem other than to say there is too much thread on the back side of the fabric.  I had been sewing for about 30 minutes when it began.  It looks like maybe the bobbin thread is catching each time.  Like the first time the bottom thread is 1 strand.  The next stitch pulled through 2 and then 3 and so on.  That's the best way I can explain what is going on.  I am 1 foot of trim away from window treatments that have been diving me mad since I started them 2 MONTHS AGO!
  • buhhhh Feb 25, 2009
    Everything is done correctly, but the tension seems off no matter where I put it. Lots of excess thread on my projects.
    Scholar:
  • 69 Answers
It sounds as if the machine is not threaded correctly so there is no tension and the result is a wad of thread on the underside of the fabric. Make sure your presser foot is in the up position and try rethreading the machine. If this does not correct the problem, check your thread path, sometimes you will get pieces of thread lodged in the tension assembly, especially between the metal tension disc. Make sure your tension dial is set between 3-5 to begin. You can adjust it higher as needed, but hopfully you won't need to be higher than 5, if so, you probably need an internal adjustment.
Posted on Mar 01, 2009
Model 525B. Why is bottom stitch loopy and the hand wheel and needle jam?
try a new needle
try adjusting the top thread tension to see if that helps the bottom loopy stitch
Jan 10, 2016 | Janome Sewing Machines
Thread tension
BOBBIN TENSION: BOB THE BOBBIN CARRIER AND BOBBIN WHILE ADJUSTING TENSION. WHEN IT WILL EXTEND ONE INCH IT IS RIGHT.
TOP TENSION: USUALLY A GOOD STARTING POINT IS THREE. THE TENSION IS RIGHT WHEN THE KNOT IS FORMED IN THE CENTER OF THE FABRIC.
TOP TOO TIGHT: WILL PULL EXCESS AMOUNT OF BOBBIN THREAD UP THROUGH THE FABRIC.
TOP TOO LOOSE: THE BOTTOM OF FABRIC WILL HAVE EXCESS AMOUNTS OF THREAD. USUALLY A MESS OF THREAD.
Dec 27, 2014 | Sewing Machines
Thread tension will not adjust.
Check your setting, you have your stitches set too far apart. Wherever on your machine you see the zigzag stich you will see other stich settings, look at it until you see the right amount of stiches you want.
Mar 06, 2017 | Brother CE8080PRW Limited Edition Project...
How to guide thread on kenmore 158.13201
Most machines are very, very similar, therefore, no matter what brand you own, there's basically the same steps to follow: 1. Place good quality thread on spool pin, back right-hand side of machine and raise presser foot UP. 2.Pull thread taut from spool.Make sure silver take-up lever raised to highest position. 3. Guide thread under first tension disc. 4. Hold thread taut, guiding thread into next tension disc. When you get to the take-up leaver (silver lever on right side of machine that has a hole at the top--hold thread taut guiding it from right to left through hole, bring thread down left side of it, and put thread into tension bracket, hold thread taut! Put thread in back of needle into another small bracket and pull thread towards you. Time to thread needle: put thread front to back into eye of needle. Put thread under presser foot and pull under the center of it a good 6".Lower presser foot on scrap of fabric to test. Turn hand wheel toward you to lower needle into fabric scrap. Use foot (or knee depending on machine) to start machine. Do not pull or push fabric but gently guide it. Jimmy Place fabric scrap under needle. Low
Apr 04, 2012 | Kenmore Sewing Machines
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
sew.
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
What's wrong with the machine when the thread is skipping on top and bottom.
hi, it could be several things
damaged needle---try new needle
needle is not correctly inserted into machine----flat side of the needle goes to the back of the machine
wrong size needle for the fabric--choose a needle to suit thread & fabric
the wrong foot is attached--select correct foot
if you check all these things & they don't help then it's possible the machine is out of time
Sep 08, 2011 | Simplicity Creative Spirti PLus SA2200...
The bobbin case keeps getting pulled out of its slot as thread is caught on a part as it attempts to pick p bobbin thread
Did you floss the bobbin holder to make sure you don't have any bits of thread, you put the bobbin case back in correctly, have been changing the needles frequently and according to type of fabric just like regular sewing and have been using the lint brush and drops of oil like the manual illustrates?Detach the embroidery unit to use the sewing side to get the situation corrected, it's much easier on that side. Then when you have that situation corrected, run a zigzag test stitch with the thread and bobbin fil until you have a perfect zigzag going on your sample fabric sandwich--adjust the tension and you should have it.
Aug 23, 2011 | Singer CE-200 Quantum Futura Computerized...
Thread clogs up bobbin and knots up thread on back side of fabric
hi there,
well, common problem when you didn't acquired right set up of tension and clean feed dog,bobbins,shuttle race.on figure right bobbins winding.d329aa1.jpgset up counter clokwise thread rotation, set dial tension on #3 to #4, dial stich to # 8 to #12
only on cotton fabrics,others fabrics such as silk..etc,gradually adjust tension fine the smoothest adjustment,
on fig,thread looping top side threading50302ec.jpg follow threading so you can have fine sewing.also clean under bobbins from chips fabric and dust.have a nice day,don't forget to rate my fix,ythanks a lot
May 16, 2009 | Necchi 3101 Mechanical Sewing Machine
Excess bobbin thread under the fabric
I know you hate to hear this but you are probably threading it incorrectly. Make sure that the presser foot is in the up position when you thread the machine. This ensures that the tension discs are open and the thread makes it in between the disc.
Feb 27, 2009 | Sewing Machines
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Janome Hello Kitty 11706 Mechanical Sewing Machine Logo
812 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
