Question about HP Pavilion TX2510US Notebook
Startup/shutdown I slide the power button on and it turns on. then it takes the better part of 3 minutes to get though the start up screen. sometimes it doesn't start up, then the hd indicator light flickers on and off every second. then, when it does start up, i go to shut down, then it takes forever to shut down. it only shows the shutdown screen and then the circle next to it. help? please?
  • lsgarrow Feb 25, 2009
    not really. it seems that i have to burn the copy myself. weird. so, lets say i burn the vista cd...
    I'm goin to buy a new hd and use clonezilla to copy over what i have...
    thanks alot! i would've never of guessed the hd failing :D
    President:
  • 2,653 Answers
Sounds like a failing hard drive.
Have you got an XP or Vista cd around?
Posted on Feb 25, 2009
Black Screen
this is a power related issue. Try to remove the battery, remove any cd that may inside the cd drive, remove any usb or anything connected to the pc like a network cable. and remove the charger as well. Now press and hold the power button for about 2 to 3 minutes.This might have been caused by improper shutdown or power fluctuations and or if you slide your laptop on a bed or carpet, this builds up static electricity around the computer's motherboard and may prevent it from starting up properly. Then after pressing the power button for that long, replace the battery only and try to switch on the machine and observe. I hope this will solve your problem
Aug 23, 2013 | Computers & Internet
Mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
Sometimes when I start my HP pavillion dv5 2135dx laptop the screen is dark even though the computer is up and running. It may take several shutdowns and startups for the screen to finally come on. Other...
If you can very vaguely see the icons or pictures displayed on the screen even though dark it maybe either a problem with your inverter or Lcd backlight. If no images are seen even though you look carefully then it may be the onboard vga controller. It maybe worth checking to see if your laptop is under warranty with Hp see link.
h10025.www1.hp.com/ewfrf/wc/weInput
I
Feb 27, 2011 | Computers & Internet
Dear Sir I just bought a verbatim 500 GB external
When you press the button it takes a few seconds for the indicator light to come on because the drive is initializing on startup, in other words its starting to spin up which could take a few seconds. Press the button one time and wait 30 seconds to see if its just the delay for the Hard drive to come to speed. And the same for the shutdown it may take a few seconds for it to park the drive and shutdown.
If this helped give a thumbs up.
"Patience is a virtue" I read that somewhere.
Aug 17, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
HP Pavilion PC blue screen shutdown and startup problem
the blue screen is known as the Blue Screen of death
refer to this article
http://pcpills.blogspot.com/2009/05/escape-blue-screen-of-death.html
Aug 07, 2009 | HP Pavilion tx1000z Notebook
IBM Thinkpad t60 won't start properly
I think the installation has corrupted some files on your operating system. Try to repair the operating system using the installation cd. That shud fix you problem
Thanks for using Fixya. A Fixya rating is appreciated !
Feb 07, 2009 | IBM ThinkPad T60 Notebook
Toshiba M45-S165 startup issues
This is normally a motherboard issue. I had one with the same symptoms and I had to replace the motherboard. Worked great after the board was replaced. I had to replace the board because unlike your issue mine stopped working all together. It did take a while before it quit though. Just a note: I have had to replace several of these motherboards for customers as well. If your LCD is broken, you may be better off to save your data and put it in a new laptop that would include a warranty unless your super fond of the machine or you have access to inexpensive parts.
Hope this helps...
Jan 30, 2009 | Toshiba Satellite M45-S165 Notebook
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion TX2510US Notebook Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
