Question about Kenmore 47792 / 47794 / 47799 Electric Single Oven
Older Kenmore single oven/microwave ovens model # 49425 or 49429. All at once oven started beeping and flashing "fault F8" and don't know what to do. Can you advise?
  • 15,935 Answers
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Oven pre heats then beeps with "F 2"
Hello,If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board.
If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically.
Thanks
May 28, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
May 21, 2010 | Jenn-Air JJW8530C Expressions Collection...
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The fan start coming on after the oven is heated up then f10 starts flashing and the oven starts beeping on my kenmore elite convection oven
the only codes ifind for the f 10 is defective touch pad.. ck the glass alligament /ribbonconnector / replace touch pad if necessary / . this may be a thermadore buit unit / there f10 states also to replace the contr board .. hope this helped **** ..
Dec 04, 2009 | Kenmore 47783 Electric Single Oven
I have a majic chef oven, when i turn it on it beeps and flashes
Self clean on some older models can cause some issues. F-3 is a sensor error. This could have been damaged by high heat or in some cases if the sensor is ok, the control doesn't know it's there.
Mar 14, 2009 | Magic Chef 9815 Electric Single Oven
Electric Diagram for Kenmore Model 790
Has the oven run out of control or gotten too hot? The 790 series is made by Frigidaire and those fault codes are F0 to F8. F2 indicates the temperature sensor is reading too hot. Now with the double oven models, some manufactures add an extra digit to the fault codes to indicate which oven created the fault.
Your most likely fix is to replace the temperature sensor. The most probable locations for the wiring diagram is taped inside the bottom drawer, on the back or under side of the oven, or behind one of the panels on the back of the oven. This might tell you the room temperature resistance for the temperature sensor so you can test it with an ohmmeter and be sure that it is faulty. Try Appliance Parts Pros for replacement sensors.
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I HAVE AN OLDER MODEL KENMORE LIMITED EDITION STOVE/OVEN. I DON'T HAVE THE MODEL NUMBER OR OWNERS MANUAL. ANYWAY, I HAVE A PROBLEM, I TRIED TO USE THE OVEN BUT AFTER I SET IT " F5" COMES UP AND IT BEEPS...
you can get the model number and serial number from the oven, just open the oven drawal and get the number and call the customer service from where you got this oven from.
Dec 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Beeping sound and f8 displayed
F8 means to replace the elctronice range control board. Evidently the power failure caused damage to the board.
May 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
F2 is aproblem with the oven sensor part number WB21X5301
Mar 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 47792 / 47794 / 47799 Electric Single Oven Logo
163 people viewed this question
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
