Question about Sony PlayStation 2 Slimline Console
Buzz Jr. controllers fail after short period of use
Unable to control menu for Jungle Party. One or more controllers tend to become inoperable after 1-2 hours of use.
It is broken.
Posted on Feb 25, 2009
The 'CONTROL LOCKED' light is on and I am unable to use the dryer.
Have you tried turning the control lock off by holding down the designated button or buttons to do so? If that does not work try disconnecting power from the machine for a short period of a time and then reconnecting to see if a reset resolves the problem.
Jun 21, 2012 | Whirlpool Dryers
Dell UltraSharp 2001FP (Gray) 20.1" LCD Monitor
Most likely, this is failing "inverter."
The backlight of the monitor (that makes the image visible) is controller by a special chunk of electronics called an inverter. They tend to fail over time. The symptom is that the backlight either never comes on, flickers, or shuts off after a short period of time.
It is a moderately advanced repair job to change out the inverter, but you can usually get the part on eBay. Search for the exact monitor model number and "inverter".
The 2001FP has six lamps and the inverter is fairly expensive. You might be better off putting that money towards a newer monitor.
Apr 11, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Ignitor gets hot and gas ignites, only runs for short period of time. then goes out. short time latter same thing.continues to cycle this way, clothes don't dry
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. Enter your model # for diagrams and illustrations of your specific model.
Oct 13, 2010 | Dryers
Control panel that controls oven went blank,oven doesn't work now
HI. There may have been a surge or pulse in this situation here. When this happens, normally, the control board will become inoperable, causing the circuits to fail. Try to reset the unit by unplugging for three minutes. once the three minutes have passed, simply re-introduce power to the unit once more, and try to operate the control normally. If it is still blank, and not responding at all, this will confirm that the damage is severe. This will require you to replace the control board in this case.
Replacing the control will correct this issue.
Oct 11, 2009 | Kenmore Kitchen Ranges
WHERE IS THE POWER WINDOW FUSE ON MY 2002 MERCURY SABLE?
The power windows don't have a fuse, they are controlled by a part called a GEM, this stands for Generic electronic module, if the wipers work ok then the power windows have power available, the problem is if the GEM fails the power windows become inoperable, what is the exact nature of the problem you have, I am a Ford rained tech so know the system very well.
Aug 17, 2009 | 2002 Mercury Sable
We had a lighting storm and the current went off. When the current came back on the oven door locked and now wont open.
The lighting has sent a surge though the control board, in return, causing a short within the main control circuits.
The EOC(electronic Oven Control) is unable to send the unlock command. it is shorted at this time. replacing this failing oven control(EOC), will restore the normal functions of this unit.
Normally, you would recive a door lock malfuction error code in this case to signal a door lock mechinism failuer but, in this case, the control has took a direct hit and, it is unable to fuction correctly.
Jun 15, 2009 | Maytag CWE4800A Electric Single Oven
Kenmore Elite HE5 inoperable and F70 error code.
HI, this error code represent a major control issue within the main control. simply replacing the main control will fix this issue. the logic chips are damaged.
May 30, 2009 | Kenmore Elite HE4 Electric Dryer
Car wont start fault code 47. how to fix? 1993 XJ6
Fuel Fail 47 Idle speed control valve - coil 2: Open or short circuit.
This code 47 is signaling a malfunction that has occurred within the Idle speed control device. the code is saying that the circuit is inoperable at this time and you will need to service it or replace the entire device.
This is basically A computer-controlled air bypass valve located in the throttle body. It helps control idle speeds by allowing air to bypass the throttle plates as to increase the idle speed.
please rate and have agreat weekend:)
May 15, 2009 | 1995 Jaguar XJ6
Unit makes a loud buzzing sound whenever the unit has power.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 23, 2008 | GE JVM1860 Microwave Oven
Sony PlayStation 2 Slimline Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
