Question about HP Compaq nc8000 Notebook
Lines on the Screen
Hi.
Have a Hp Compaq nc8000 ( I know I know, Get with the times). My Current Problem is the I am now seeing lines on the screen and attempts to Reboot/Shutdown are not Fixing the problem. Switching the Monitor over to external is not helping at all. I think the problem might be the video card is bad. Is the card integrated with the board and can i change it if it isnt?
  • shadowfox490 Feb 25, 2009
    Thanks for the Fast Response. It was a big help
    President:
  • 2,653 Answers
It's onboard with that model. Replacing the motherboard would be the only way to make it go away.
Sorry to be the bearer of bad news.
Best of Luck!
Posted on Feb 25, 2009
Hp compaq nc8000 external glass between thin line coming like glass are broken
You maybe able to get a replacement screen from this WEB site.
LCD screens and Inverterswww.lcdparts.net
Mar 24, 2012 | HP Compaq nc8000 Notebook
Hp nc8000 external glass between line
www.lcdparts.net
My compaq nc8000 will try to boot up (only shows window xp, then goes to a blue screen with a lot of dots in it), but first shows zeros all across the screen not allowing you to do anything at all.
Hi, sounds like what is known as the blue screen of death. You can try reseting your operating system to an earlier time, before the problem began, by pressing the ESC or Del key during bootup, this will give you the option to boot into safe mode, from where you can attempt the reset. Or you can insert the CD that came with your compaq and perform a system restore. Both of these options will not remove any saved data.
Oct 11, 2010 | Compaq NC8000 Notebook
The screen on my HP compaq nc8000 laptop goes blacks usually after the screen has been closed. the screen is very dark after is hardly visible except when squinting. does anyone know what the problem is or...
The culprit will be the inverter board of your LCD screen that drives the backlight, my nc8000 shows the same symptoms after 6 years of heavy daily usage. After pressing the LID sensing button near the right hinge the backlight usually remains on, but sometimes you have to press it several times under a minute once it finally stays on. The proper fix would be to disassemble the screen and replace the inverter board, as the LCD and the CCFL backlight tubes are perfectly fine in my case.
On how to remove the screen from the laptop, you can get help from this HP guide:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00803690/c00803690.pdf
(it's in section 5-35, that starts on page 128)
Unfortunately, I can't help you out on the other part, on how to disassemble the screen itself (but I suspect it has 4 or 6 screws under the rubber "feets" on its front), and I can't help you out in fixing the inverter board itself either...
If you want to fix the board yourself, you have to be able to wield the soldering iron perfectly, and your goal will be to replace some capacitors (they are usually bulging, so you can identify them being the culprit by the naked eye too).
The other option is to order a replacement inverter board, and simply swap the bad with the new one, it is still more economical than to buy a new display assembly as a whole; some chinese manufacturers are available, but I bet you can find some source more closely to your current location, just google for:
hp nc8000 inverter board
Aug 12, 2010 | HP Compaq Business nc8000 Notebook
Hi I have a 2 inch wide vertical white band on my screen.It is faint and other screen material can be seen through it.
This is a sign your monitor is getting ready to go out. The only fix is a new lcd. Check with your local authorized Compaq/HP dealer for more information.
Good Luck
C2S
Jun 26, 2010 | Compaq NC8000 Notebook
My compaq monitor fs7600 has flashing thin lines running up the screen then the lines bunch up together and the rest of the screen in left black help please
Hi Rubee,
Please get into BIOS mode and check whether there is a flashing lines. If Yes, change your video card or contact your Hp technician.
Jun 14, 2010 | HP Compaq FS7600 17" CRT Monitor
White vertical line on my hp compaq nc8000 monitor
Hi there welcome on fixya.com!
Try another screen and tell me if you still have the line !
Apr 04, 2009 | Compaq NC8000 Notebook
Red and Blue vertical lines top to bottom on LCD Screen
yes it looks like its going bad..must be pixel burnout or something..you will have to contact HP for repair/replacement
Nov 23, 2008 | HP Compaq nc8000 Notebook
Have hp compaq nc8000, has lines running vertically down screen. have a feeling it's a top of the range screen, but don't know where to look to confirm the type of screen
usually it will tell you if you right click on your desktop and go to personalise or somthing to that effect then go to settings. it should say just underneath the little box with the windows in it.
more help needed then email me on milliprowd21@yahoo.co.uk
regards
matt
Aug 21, 2008 | Computers & Internet
HP Compaq nc8000 Notebook Logo
136 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
