Question about Maytag MSD2756G Side by Side Refrigerator
Filter light I changed the filter but the red light stays on. I've missplaced my manual.
Press andd hold the "Light" button and the "Lock" button simultaneously for several seconds.
When released, the Filter light will go off.
Posted on Apr 12, 2009
2005 Suzuki boulevard c-90 I changed oil and filter but the oil light stays on so I changed the oil and filter again and the oil light is still on .
Hi, Gene you may have air in the system try bleeding it out like you would for brakes by loosening the oil pressure switch or oil filter with the engine running and watch for bubbles when they stop re-tighten and your good to go, for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Red Oil Light Stays On
Oil light coming on
Suzuki C90 Oil Change and Final Gear Oil Boulevard
Suzuki VL1500 Service Manual
OEM parts for Suzuki
Suzuki VZ1500 Owner Manual
Oct 21, 2016 | 2005 Suzuki Boulevard C90
Green alarm light continuously on. Any ideas?
Green light usually means your water filter is in great condition . the light will stay on,over time change to amber then red. Red means change filter
Jul 22, 2015 | Refrigerators
Need universal remote code.
Hello
Three digit universal remote codes for konka are:
016/ 047/ 066/ 157/ 158/ 176
Four digit universal remote codes for Konka are:
0053 0011 0016 0047 0066 0103 0412 0413 0029
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Mar 25, 2011 | Konka K2038U TV
We changed the filter on the icemaker but tye light is still on asking for a filter. now what makes the light go out?
The light stays on, actually. RF265/6/7 models have a blue LED water filter indicator that remains lit in normal mode. After about 5 months [on a 300 gal. filter] the LED indicator will turn pink and then red at about 6 months. Derived from RF266 users manual, hope this helps.
Oct 07, 2010 | Samsung RF265AA Bottom Freezer French Door...
Red light stays on after changing the water filter and running about 2 gallons through it
Water Filter Status Indicator
Light (select models)
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Changed water filter red light stays on
you will wither have to push the light switch button 5 times or push and hold reset button or 2 at a time. Look at the display carefully it usually will tell you what you need to do
May 27, 2009 | Amana ARS2464B Side by Side Refrigerator
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
After changing filter the light will not go off red
you need to restet the filter indicator light. donload the instructions from samsung
Mar 25, 2009 | Samsung RS2630SH Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
104 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
