Question about HP Pavilion dv4000 Notebook
Hp pavilion tx1000 screen its loose
Hi, im not good with english but Ill try my best..
I have had this hp pavilion tx1000 notebook for a year...
information and picture:
The problem is... that the screen its loose, its not tight enough.. so it flaters a lot... It got like this is because the use.... the screen rotates and moves far down... so it got loose.....
another problem is that I cant go somewhere to fix it, because there is no place... I live in a really small town that its kind away from city...
Anyone knows how to disarm the screen so I can personally make it tighter?
thanks a lot!!!
Hey i just fixed that.. except i broke one very IMPORTANT metal part i think i fixed it with epoxi solder. here it is but that guy just tighten the 4 screws.. youll si if those are loose.. but mine werent. youll have to take those screws, and then take that little part off (just pull. if its loose, will come off really easy) then put some tape, or paper to make it tight, and hammer it back on and youll be set. you can make it softer (the friction) by loosing the screw nut on both sides.
when i broke mine, was when i was pulling up the beezel the part with the HP logo. the speakers were hard, really hard, but that hp last part was REALLY HARD.. well and it broke.. the left little metal part. think ive done something wrong. i hope doesnt happen to you. my english isnt good either.. my first languaje is spanish.
good luck!
Posted on May 15, 2009
  • 2,653 Answers
Even after getting the laptop apart you won't be able to tighten the hinges because of the way they're manufactured.
You'll have to buy replacement hinges.
They go for about $30 on ebay.
Here's what they look like:
You should be able to take the laptop apart yourself. If you ask for a service manual here, someone might be able to dig one up for you.
Best of Luck!
Posted on Feb 25, 2009
  • Ricardo Soto Sep 18, 2010
    Well I managed to tighten the hinges, is just a matter or using some pliers and grabbing the nut at both extremes and rotating them clockwise. My problem is that while mi wife was opening the LCD case, she broke the plastic counterpart that is attached to the hinges, so now I'm doomed. I just pasted with some instant cement the metal hinge to the plastic cover where the counterpart once was. I'll tell you how it went.
Need a replacment or new motherbord for tx1410us
The Pavilion tx1410us Notebook PC is one of the Pavilion tx1000 series of Notebook PC's.
Here is the download page for a free Service Manual,
Go to the 18th line down. The line that starts with HP Pavilion dm1.
Go to the second line and across to tx1000.
Left-click on tx1000.
This is a PDF file. You may not see anything happening for up to 30 seconds after you click.
The file is downloading in the background.
After you see the first page it may take additional time for the file to fully download.
Suggest you let the file download all the way before looking through it.
Nov 25, 2010 | HP Pavilion tx1410us Tablet PC
Have you checked your power supply to make sure that it's putting out the proper volts and amps, or if it's shorting out in the wire or possibly internally. I've run across a few where that was the problem; which had similar symptoms to your tablet\touch screen. If the power adapter is bad, then you might as well buy a replacement off of ebay. HP will likely want an arm and a leg for one of theirs. I like HP laptops, but I have to admit that I've been pretty disappointed with them as far as being "long lasting". HP has had some serious issues with their laptops over the last few years.
Mar 25, 2010 | HP Pavilion TX1000Z Tablet Notebook PC
My hp pavilion tx1000 laptop display got off( not displaying any thing
Two possibilities, your backlight is loose and needs checking or even replacement, or the cable connecting your screen is loose or mulfunctional. The first case if the most likely and common case. Considering how narrowly your screen connects with the rest of the computer and how on many occassions people 'just looove' to swing that screen around, it comes as no surprise that after a while it would start acting up. If you're into dismantling and reassembling computers, well, try and access the cables connecting your scree, check them and make sure they are okay, next, check your backlight and all its connections just to make sure everything is seated okay [all the above will require that you open a few things here and there] Good luck
Jul 11, 2009 | HP Pavilion TX1000Z Notebook PC
Touch screen drivers for tx1000
go to the HP website and put in your model number you will get the drivers
May 04, 2009 | HP Pavilion tx1000z Notebook
Pavilion TX1000 - WiFi card suddenly not detected
The solution is, get a USB wifi adapter, because that card is done. HP REFUSES to recognize this problem, and since the majority of failures happen after the warranty expires (mine did) HP just says you are SOL. You can get decent wireless adapters for $20, and your wireless problems will be solved. Unfortunately, expect your laptops motherboard/chipset/dc port to fail within a year :(
Apr 17, 2009 | HP Pavilion tx1000z Notebook
Calibration of touch Screen is off - Can't re-calibrate.
I had the same problem, also on a HP Pavilion tx1000.
I solved it by using the driveres from eeti.
Now the pen works great and I'm a happy camper. :)
Feb 01, 2009 | HP Pavilion tx1000z Notebook
Broken touch screen glass
they've got screens for about $205 for the tx2500 and the tx1000 with easy to understand manuals on ebay at the following site:
Sep 23, 2008 | HP Pavilion TX1000Z 12.1" Touch Screen...
Help with my hp tx1000 please
Mine has already twice made the same thing. Solution was simple - got the touchscreen changed (luckily under warranty). As third problem required change of the motherboard, I'm planning to get rid of the piece of junk alltogether. I think it is a solution for all the troubles with tx1000.
Jul 01, 2008 | HP Pavilion TX1000Z 12.1" Touch Screen...
HP tx1000 driver for winxp
hi, is there any letters after the tx1000
Feb 20, 2008 | HP Pavilion tx1000z Notebook
HP Pavilion dv4000 Notebook Logo
1,607 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
