Question about HP Compaq Evo Notebook N600c
Wireless internet wont work
When i put the wireless card in it doesnt work
    President:
  • 2,653 Answers
Can you try the card in another laptop to see if the problem is the laptop or the wireless card.
If you have any more questions, we'll go from there.
Posted on Feb 25, 2009
  • RescueTechLA
    RescueTechLA Feb 25, 2009
    Did you still need help with this?
Smc 802.11g adapter doesnt show in wlan utility
update the wireless drivers for your network card. also check the spec sheet for your wireless card and make sure it's compatable with your OS and system.
May 01, 2014 | SMC EZ Connect g SMC2862W-G 802.11g/b...
My internal wireless card is failing. I purchased a new one. A tech told me if I replace the old wireless card with a new one the system won't load, something about HP locking the bios. Does anyone know...
The wireless card wont be locked to the bios. Swap it out and install the drivers once it is loaded. It will just see it as a new piece of hardware.If it doesnt work, take the new one out and put the old one back in, it wont destroy your computer.
Jan 26, 2011 | HP Pavilion zd8000 Notebook
My internet with my wireless card cuts out often
Update your drivers.
I used to have this card its sktechy.
If new driver doesnt fix it I would recommend selling it and using that money to buy a new one.
Apr 06, 2010 | Linksys (WMP54GS) 802.11g/b Wireless...
Laptop doesnt connect to wireless internet (wireless card is fine
When you reformatted your HD, did you use IBM's method which utilizes a hidden partition? This results in a laptop which appears to be as if it just came from the store, like a brand new laptop.
This method sets up the computer in the exact way that IBM built it. And puts all devices in their proper configurations.
If you have not done too much yet, you might want to try that method right away and see if it doesn't make a big difference in the way your laptop works.
-a.
Feb 19, 2010 | IBM ThinkPad T42 Notebook
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Wireless wont connect properly
Are you using the windows utility to connect or one that came with the laptop wireless card ?
It is possible that the two different things are both trying to control the card and only one can actually do it !
I usually let windows do it for me and then goto control panel, administrative services, services, and turn off the wireless zero config services and disable it.
That usually ensures a more stable wireless connection.
Unless you need to have a specific IP and have also given it the DNS serever as well then quite often it is better to set the TCP/IP properties for both IP and DNS to automatic.
That should fix you up but just in case it doesnt make sure you 100% have the correct drivers for the wireless card. Some drivers nearly work but not quite and I have seen them cause problems similar to yours
Aug 10, 2009 | Acer Aspire One A150-1006 Notebook
Pcmcia wireless card will not connect to any network
Try the laptop and the PCMCIA cards at an internet cafe. IF they don't work there as well, I recommend you throw the cards away or give them away and buy your self some new ones.
Nov 18, 2008 | Computers & Internet
Medion 95400 Wireless switch on keyboard not working
got o control panel and on device manager check the properties of wireless card. it might be off. theres an option that ll let u power the wireless card on n off from threre.
Nov 05, 2008 | Computers & Internet
3com router doesnt work at all
contact your ISP for proper settings for the router.
Nov 11, 2007 | 3Com OfficeConnect Wireless 108Mbps 11g...
HP Compaq Evo Notebook N600c Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
