Question about Fisher and Paykel GWL11 Top Load Washer
Whirlpool LSR5232LQO top load washer.no cold and warm water.could it be the pump? need help.
  • 117 Answers
Probably the water valve is faulty :( If you get hot water and not cold but hear a buzz from the back, you will need a new water valve. Hope that helps......
Posted on Feb 25, 2009
No cold water on cold/cold or warm/cold setting
Try shutting off the hot water valve on the plumbing and start the washer with a warm water setting. If you get no cold water, check to see of the cold water hose is plugged with debris, if not the cold water valve may have a broken or disconnected wire. or the valve may have failed. Hopefully it is just a plugged hose.
Apr 29, 2014 | Whirlpool LTE5243D Top Load Stacked...
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
No cold water Whirlpool top load washer AP595033
Your cold water celenoid has gone out. There is no way to just replace the cold itself, So you have to buy the whole water valve. That will fix ya up!
Nov 17, 2008 | Whirlpool GHW9100L Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
108 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
