Question about Maytag 24 in. MDBH940AW Built-in Dishwasher
Maytag dishwasher not draining completely
How do I get to the drain pump to see if there is a blockage. It is built in to the cabinet. Do I have to take it completely out?
  • 117 Answers
You have to remove the bottom kickplate to gain access to the drain pump and drain hose. You can remove the drain hose and blow through to see if the obstruction is in the hose. Take a look at the check valve for blockage. If a garbage disposal was just installed, make sure the knockout plug was removed.
Posted on Feb 25, 2009
Water doesn't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 03, 2011 | Maytag MDB8851 Built-in Dishwasher
I replaced the drain motor since when using the manual function test it didn't drain and the pump was silent. After I changed the pump but before I put the dishwasher back in the cabinet I tested the...
Make sure the wire harness is secured properly to the pump . Also just make sure the drain line is clear. If this is not the problem most likely the control board needs to be replaced.
May 05, 2011 | Maytag MDB9600A Jetclean II Built-in...
My maytag dishwasher won't drain. It is not clogged. It just won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Jan 31, 2011 | Maytag 24 in. DWU9202 Built-in Dishwasher
I have a small dishwasher it goes through all cycles water won't drain out of the bottom
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
Water does not empty from dishwasher
Hi
Thanks
Rylee
Jul 04, 2010 | Maytag MDB9750AWS Built-in Dishwasher
Water is not draining Maytag Jetclean
Hi
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 24, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwasher is not draining
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 04, 2009 | Maytag 24 in. MDBH955AW Built-in...
My Maytag dishwasher Model # MDB-3 will not drain. Please help. Thanks! Anna Giacobbe
Hi
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Water will not drain out completely
You probably have a partial blockage in the drain line or the drain pump. This is not difficult to check. Just open up the panel below the door of the dishwasher and look for the flexible drain line. It is attached to the drain line pump. Unscrew the pump from the dishwasher frame, disconect the drain line and take a look at the pump and the drain hose. You may find a piece of glass or other hard object that is causing the problem. good luck.
Jan 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag dwc7400abw
you have a blockage somewhere probably. if the drain hose plumbed in under the sink, check there is no blockage in this area. also check the drain hose for blockages. if all clear, the fault is probably the drain pump itself
May 05, 2007 | Maytag 24 in. DWC7602 Free-standing...
Maytag 24 in. MDBH940AW Built-in Dishwasher Logo
230 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
