Question about Garden
Honda snowblower problem
I have a honda hs 1132 snowblower.Last year the motor ran fine this year I start it and the motors rpms go up and down at high speed.Is there an ajustment for this.Ive taken the carb off dissasembled and cleaned it but it still does it.
  • klkst Mar 01, 2009
    I had to replace the carb, tryed to clean with no luck. Honda dealer said it a common problem passage ways are so small they sometimes need to drill them out. I removed the gas each year there is no fuel filter on this snow blower just a screen in the tank so I added an in line filter. The machine is 8 years old this is the first repairs I had to do.
    Thank you
  • 398 Answers
Yes you can adjust the throttle cable, did you leave gas in it over the season, if you did this is definitley the problem, dump out the gas and pour new.
Posted on Feb 26, 2009
  • josh1111 Mar 01, 2009
    you may be losing compression in the motor, does the compression feel strong when you pull start? if you tried to adjust the throttle and still no avail, it probably is the engine, the piston rings go bad.
  • josh1111 Mar 07, 2009
    get an rpm tester
My snowblower starts then stalls
Rob; 95% sure it is a carburetor issue, dirt clogging a port or jet,float sticking. I will post a few sights below to show how to clean carb.
How to Fix Snow Blower Carburetor
HOW TO Clean Rebuild Tecumseh Snowblower Carburetor PART 2 OF 4
how to rebuild snowblower carburetor
Jan 30, 2016 | Cars & Trucks
Change right and left auger on a honda 1132 snowblower
Have you not gone to a Honda Dealer
for the correct parts?
Dec 09, 2014 | Honda Cars & Trucks
Why is my 2000 honda civic ex keep shutting off when it gets over 4000 rpms
After 14 years I think it would be reasonable to have bad catalytic converter. Is there some reason your not accepting this?
May 04, 2014 | 2000 Honda Civic
I installed a new GX 390 Honda engine in a Toro 413 TX machine. Motor starts, idles and full throttle fine, but when hydraulics,i.e. drive is engaged, motor dies.
you have a dingo, ugh
I would suspect a bad pump or wheel motor if the rpms are set correctly and no safety switches are causing it to die...
Dec 26, 2013 | 13 HP Electric Start GX390
Starts and dies but doesn't run until you get 1000 rpms , then ru
common problem on honda is idle control motor located on intake/throttle body.
Dec 25, 2009 | 1988 Honda Prelude
Broken choke control on snowblower
hi jared
the chokeis connect to the carb.it opens and close the trottle.try to locate where to connect the cable to opperate the trottle
bye
Jul 02, 2009 | Honda Garden
Honda snowblower engine hunting
Sounds like you are hitting the governor. Watch the arms at the carb when you move it to full throttle. The arm should hit a screw. Turn this screw clockwise, until the reving stops.
Dec 08, 2008 | Garden
Rpms up and down/idlind
hey
il give you a list of problems it could be...its a problem that could come from a wide range of sensors etc
try changing your TPS (throttle positioning sensor) its located on the intake area (look where the throttle cable hooks to the engine) Possibility of a fuel pressure regulator problem. Also a faulty Idle Air Control motor (IAC) could cause the problem. computer may need to be reset. (disconnect the battery for bout 15 mins) possibly a vacuum leak...check hoses, you may need to replace your intake maniflod gasket
Sep 08, 2008 | 1994 Honda Civic
Rpms up and down when driving on low speeds
did they check radiator cap? Or your reservoir? My car did same thing, they flushed air out of cooling system, and replaced thermostat.
Garden Logo
606 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
