Question about Hamilton Beach BrewStation 47214 Coffee Maker
Our hamilton beach 10 cup brewmaster coffee pot which is programmable will not brew more than one cup even thow you want the whole pot to brew. we cleaned as reccommended. any more help with this problem would be appreciated. it is a fairly new pot purchased two months ago. thank you. nicole
If you have tried tried to clean the unit according to the manufacturer and the problem still persists you may have a something that has become lodged in the check valve. Unfortunately, unless you have a special screw driver required to remove the two anti-tamper screws fastening the bottom cover to the unit, and are willing to void the warranty if still covered, you will not be able to service the unit yourself. If so, before preceding make sure the unit is unplugged from the electrical outlet and any water remaining in the holding tank is removed by holding the unit upside down over a sink. Caution water may still be hot.
With the bottom panel removed locate the rubber hose connecting the heating tube to the bottom of the holding tank. Important... Before removing the hose be sure to make note of the orientation and position of the check valve as it must reinstall in the same direction and position in the hose. To remove the hose slide both clips toward the check valve and remove. Note that the clips are of different sizes. The large is used on the tank end, the smaller is used on the metal heating tube end. With the hose removed, carefully slide the check valve out of the tube and remove any debris that may have become lodged in the valve. You may need to remove the plastic ball from the three prong holder to do so. Do not use any sharp metal objects to remove the ball that could damage it. Once cleaned reassemble the valve and place it back into the hose. Reattach hose making sure not to leave any kinks in the hose and that the check valve is properly installed in the same direction and position in the hose as before. Besure to reinstall bottom cover before returning the coffee maker to service. To prevent electrocution.. Do Not plug unit in with bottom cover removed.
Posted on Mar 29, 2009
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
Hamilton Beach Brewmaster 47374
The problem is the plastic valve on the bottom of the tank. If you remove the 4 screws connecting the black and white parts together it will expose the valve and you will find that at least one of the tabs that secure the valve are cracked off. You can replace the tank for a new one at HB website for 10 bucks or try to repair the valve yourself.
Apr 23, 2012 | Hamilton Beach BrewStation 47224 Coffee...
Hamilton Beach brew station dispenses very slowly. I have cleaned it twice but still takes a long time to fill a cup!
Try to have a look whether there is a limestone layer built up on the element.
That will slow it down, while most probblems will stop it alltogether.
Remove by leaving white vinegar in it overnight.
Sep 04, 2011 | Hamilton Beach BrewStation Deluxe 47474...
My hamilton beach brew stations quits after brewing 2 cups of coffee.... we have to turn it off and turn it back on several times to get the whole pot brewed. help.
You just need to run white vinegar through it. Put white vinegar in the same way you do water (but don't put any coffee grounds in the basket). Run it as many times as it takes to get all the vinegar out, and then run it again three or four times the same way. After it runs normally, run water through it until the vinegar smell is gone.
The cause of the slow brewing is that the water you normally use has some amount of hardness to it, and over time the hard water minerals build up on the heating element inside the machine. The buildup prevents the heating element from heating the water as fast as designed. The vinegar will dissolve the minerals and let the heater work at full capacity again.
If you want to avoid this in the future, just run the white vinegar through it once a month or so even if it's not running slow.
Jan 31, 2010 | Hamilton Beach BrewStation 47224 Coffee...
Keeps shutting off after one cups is brewed even if filled for 10 cups
Hi, this is a common problem with Hamilton Beach on several models. There are also a host of other problems with them. There is no fix for these coffee makers. They are "throw aways" have owned them myself in the past and understand your problem. Sorry to sound so negative but Many people are disappointed with Hamilton Beach.
Good Luck.
Aug 17, 2009 | Hamilton Beach BrewStation 47214 Coffee...
I own a brew station master and we have not had it a year yet and when we put the water in to brew 12 cups it only brews 4-6 cups we have cleaned the coffee pot with a cleaner but it has not helped
If the model you have is a 74214, I had the same problem. I had to repeatedly turn the pot off and on to get a whole pot of coffee. I returned the first one within 90 days back to Walmart with no receipt. They exchanged it with no problem The second one did the same thing so it went back also. I was going to exchange it for the same model but got lucky and found the next upgrade model (47665) on sale at that time. Not only did Walmart credit me the cost of the faulty one, but refunded me the $5.00 difference!!!! I've had the better model (47665) for about 9 nonths now and had a problem with a waher/gasket falling out causing the coffee to run all over the place. I called Hamilton Beach customer service at 1-800-851-8900 and explained the problem. They informed me that the tiny plasitc piece that holds the gasket in place had broken and I would need a whole new tank. They then informed me that for the $5.00 cost of shipping, they would send me the new tank FREE OF CHARGE!!!!!! AMAZING. I love Hamilton Beach and know that they stand behind their products. Call them at 1-800-851-8900 and explain the problem. I'm sure they will remedy the issue at little or no cost to you and if it can be repaired, I know they will send the part with instructions at no cost. Good Luck to you. Katherine
Jun 28, 2009 | Hamilton Beach Coffee Makers & Espresso...
My hamilton beach brew station 10 cup makes 2 cups then stops
Is it a model #47214? If so, I had to take TWO back to the store I bought them from within a 6 month period. I bought mine at Walmart and even without a receipt they exchanged it for an identical model with no proble. The second one did the same thing. I had to keep turning the pot off and on to get it to complete one brewing cycle. The third trip to Walmart, the next better model (47665) was on sale and agin with no receipt, Walmart gave me the purchase price of the faulty model 47214 toward replacing it with model 47665 which is usually $15.00 more, but because the better one was on sale, I actually got a $5.00 refund too!!!!!!! I love Walmart. BUT.......after about 9 months using the model 47665 constantly thru the day, the coffee ran all over the counter and floor. When I checked it out to see if I could fix it, I found the small round gasket the prevents this from happening had come out. I called Hamilton Beach Customer Support at 1-800-851-8900 and explained the problem. The told me the tiny plastic part that held the washer in was broken and I needed a whole new tank. Imagine my surprise when they then informed me that for the nominal fee of $5.00 for shipping, they would send me a whole new tank, NO CHARGE!!!!! I love Hamilton Beach. They stand behind their products and until you contact them for yourself, you'll never realize how wonderful they are. Call them, 1-800-851-8900 and explain the problem. I know they will remedy the problem as quickly and cheaply as they can. Good Luck to you!!!!!!! Katherine
Jun 27, 2009 | Hamilton Beach BrewStation 47114, 12-Cup...
Hamilton Beach 12 Cup Programmable Coffee Maker
Here is a link to the manual for the model 43253 (model listed in your post's header). If this isn't your model, this link will take you to the download page where you can select your actual model.
Happy brewing! (I hope you're starting with whole beans and grinding them yourself...it's the only way to go!)
Mar 27, 2009 | Hamilton Beach (43253) 12-Cup Coffee Maker
Hamilton Beach BrewStation 47214 Coffee Maker Logo
410 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
