Question about Kenmore 24032\24036 Top Load Washer
The center piece is grinding wont spin my clothes
    Brigadier General:
  • 4,669 Answers
Transmission problem or spin bearing? Check the belt first.
Posted on Feb 27, 2009
Why is my clothes dryer making a noise as it spins?
Stop when it makes noise , re-adjusting the clothes , spin back , it makes noise when one side has more weight of clothes than other , dont put too much clothes at a time ..
Mar 04, 2017 | Dryers
Problem during wash cycle
Possibly a foreign item like small change or a piece of metal from an article of clothing, pocket?
Mar 19, 2014 | Haier RWT360BW 3.0 Cu. Ft. Capacity...
How do i fix my washing machine
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 28, 2013 | Washing Machines
Washer won't shift into spin
with a lot of the machines now they wont go into spin mode if the drum is not balanced properly, like say you had a load of towels in their, well it wont spin as its to unstable to spin without wobbling around so it simply stops at the spin cycle and does nothing, you can try this by turning it on with no clothes in and see if it will go into the spin cycle with no clothes in, if it does then chances are its not weighing the clothes properly and would end up costing a fortune to put right as it sounds like you spent a lot of money on parts all ready, so give i a try with no clothes in and see if it will spin, have you tried turning the drum by hand when its switched off to check for any grinding noises or jerking when you try to turn it by hand, im not sure how the balance sensor works or even where it is as its a new feature in the last few years but people are now starting to have problems with this feature and it stops the machine from spinning leaving the clothes soaking yet, so give it a try empty and see what happens
May 16, 2012 | Whirlpool Washing Machines
Clothes still wet
Usually due to blockage in filter or hose or pump, but may be motor brushes not spinning drum to proper speed
May 09, 2012 | Maytag Washing Machines
Kenmore 11023032100 will not spin cycle, I can hear the motor is running and water will still drain, but tub will not turn even if empty. Loud grinding noise.
First thing to check would be the drive couple here is a basic kenmore video http://www.youtube.com/watch?v=nM4DW2bq7o0 and here is another as well http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5501893181&kw=kenmore%20coupler
if you check the drive coupler and find that this is not what is makeing your grinding noise message me back for further diagnosis. whirlpool purposely makes this part to fail after your warranty runs out within two years. The upgraded part has a center metal sleve so this is harder to happen again. Usually happens quicker if you do heavy loads or loads often due to many clothes not your fault they make that piece to break. Do the repair yourself and you will save yourself a nice 150. Have any further questions message me back
Thank you
Rick
Nov 02, 2011 | Washing Machines
Washer wont spin
You may have some small piece of clothing stuck in the water pump. Pull clothes out, empty water out, turn over and remove pump and check for obstructions. If nothing in there see if it is frozen from moving, if not belt may be loose by being streched. Replace belt if needed.
Apr 16, 2010 | GE Spacemaker WSLP1100D Top Load Washer
GE Profile washer
suspect gearcase ask for estimate first..could be more than new washer
Jul 09, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
27 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
