Question about Aprilaire 550 Humidifier
Water spewing into the reservoir and ovrflowing
My Aprilaire 560 is overflowing with water. When it clicks on, the water is coming into the unit very forcefully and continuous resulting in immediate overflowing and water gushing out of the unit.
    Novelist:
  • 189 Answers
Sounds like you do not have an orifice in the water line to regulate the water pressure.
Posted on Mar 29, 2009
On my Aprilaire 560 humidifier it says to replace water panel evaporator annually. Are there any documented instructions on how to do this?
Dear Reader,
If you visit aprilaire.com, you can go to the "OWNER'S CENTER" tab at the top of the page. With the cursor on "OWNER'S CENTER", more options will appear. Click on the "OWNER'S MANUALS" option. Scroll down to the bottom of the page and you'll get to a list of our older model humidifiers. Click on the first link which includes your model 560. By clicking on this link, you will be able to download the owners manual for your 560. On page 16 of this manual will be the step by step instructions explaining how to perform the water panel change.
If you have any further questions regarding this or any of our products, please feel free to contact our customer service department 800-334-6011 at your earliest convenience.
Kind regards,
Zach Handyside
Customer Service Specialist
Research Products Corporation
www.aprilaire.com
Nov 16, 2010 | Aprilaire 600 Humidifier
Aprilaire Humid. Model 560 - not working even though water is on
Make sure the heat is running during test.Does the pump make noise.The control shoud make a soft click when u turn the knob on/off.
Mar 07, 2010 | Humidifiers
My Aprilaire 560 doesn't shut off even if the blower is off.
My Aprilair 560 turns on and off repeatedly.Making a loud banging sound.Changed my water valve worked 1 day and started agin.
Dec 20, 2009 | Aprilaire 550 Humidifier
I have a model #560..turning the humidistat forward until it "clicks" would cause the water to begin flowing..now, after the "click" is heard, the water does not flow into the reservoir. Do you think it's...
turn the saddle valve in and back out. sometimes the small pin hole for the water gets plugged with something over the summer when the units aren't running and just turning the valve in and back out clears it out and allows the water to flow. check to see that you have water flow at the solenoid and if you do then it is probably the solenoid that is bad.
Dec 07, 2009 | Aprilaire Humidifiers
Aprilaire model 560 pan keeps filling up with water - what adjustments do I need to do?
Here's a link to the manual for your Aprilaire model 560 humidifier you can download and print for free.
According to Aprilaire, it is normal for there to be excess water going into the drain pan. However, the drain pan should have a drain line connected to it so the contaminents from the humidifier can be flushed down a drain and away from the unit. (see page 2 Principle of Operation).
They further state that the water valve should only be either fully on or fully shut off and do not attempt to regulate water flow with the inlet supply valve.
http://www.aprilaire.com/themes/aa/en/manuals/Humidifiers_Owners_Manual.pdf
I would give the unit a good cleaning of the pan, locate the drain connection and attach a drain line to your unit as is required for proper operation and function/
Hope you find this Very Helpful - Best regards!
Aug 19, 2009 | Aprilaire Humidifiers
Low or no humidity.
i have an aprilaire model 550 im getting no water to the filter but i am getting water to the solenoid
May 11, 2009 | Aprilaire 550 Humidifier
Aprilaire 560 constantly drains water
check to see if you have 24 volts between to 2 yellow wires coming out of the water solenoid. if you have 24v, then it is still getting energized to run. if it does not have 24v and the water is still running, the solenoid is stuck open. most likely from water deposits. sometimes you can take the solenoid apart and clean it, but probably better off just getting a new solenoid.
Feb 07, 2009 | Aprilaire Humidifiers
Aprilaire 600 doesn't seem to be running at all
check list
1.check the clamp on the pipe where water line connects
is the hole clogged (water turned off)wont take long
2.Is water flowing all the way to resevoir after turnnig water on
loosen line at reservoir
3.jiggle float water should enter the reservoir inlet to float valevel
somestime cake up,clean float off
4.Remove pump cap clean impeller and standpipe
5.clean reservoir,and close everything up
Usually the hole in the pipe is clogged up in step 1 or the float is sticking if there is no evidence of water in the reservoir
Nov 20, 2007 | Aprilaire 600 Humidifier
Aprilaire 550 Humidifier Logo
313 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
