Question about HP Pavilion zd8000 Notebook
Computer shuts off
Sometimes i turn on my comp and every 5 minutes it shuts off and sometimes i can use it longer i think it might be the power supply.
  • lewis103 Feb 25, 2009
    yeah it does but sometimes it dosent get a chance to get hot im using it now for about 3 hours and its fine so i dont know.
    President:
  • 2,653 Answers
Does it feel hot?
Sounds like it's overheating. It's very common with this model.
Let me know so that I can diagnose it correctly.
Thanks!
Posted on Feb 25, 2009
  • RescueTechLA
    RescueTechLA Feb 25, 2009
    OK well since it's a good idea to clean out your system anyway you should try picking up some compressed air from Best Buy, Wal-mart, etc.
    Take the laptop outside, remove the battery, and then spray the vents out. Make sure you keep the can level so that it's just air, not the cold stuff.
    Give it a minute or two to rest, then place the battery back in and see if that improves anything.
    Let me know.
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
Lenovo desktop 3282 beeps twice then 5 times and goes no further
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 01, 2012 | Lenovo Computers & Internet
My computer has frozen during shutdown it has never happend before.Please help !!!
this sometimes happens with operating systems.nothing to worry just press and hold down the power button of the pc for 5-6 seconds and you will see that the system will shut down completely.then just turn it on the normal way you do and it should work fine.if it is vista then it may give you a prompt to start windows normally.just hit enter on that option.
Jan 14, 2010 | Sony VAIO VGC-RA840G PC Desktop
My laptop computer shut down when run for 5 minutes or so. Do you think is the cooling fan?
It could very well be.
Does it feel hot?
Does it last longer when you boot it up for the first time?
Dec 07, 2009 | Dell (6F858) Cooling Fan
Air condioner climbs to 86 degrees
First check your coil behind the filter. If this coil iss clogged the unit will over heat and cause the compressor to shut down. It sounds as if either the evaporator coil (inside) or the condensor coil (outside) may be clogged. If the unit is icing up on the inner coil then that coil is clogged or low on freon. I would think it would be cloggged instead of freon problem. To clean this coil you can go to the hardware store and buy a can of coil cleaner and use it following the directions The outer coil you would have to remove a/c from sleeve and take the unit outside. Using a water house flush the condensor coil from the outside in to remove debris.. These coils should look like a brand new car radiator when you finished cleaning. Reinsert the a/c back into wall sleeve after letting the water evaporate from the unit as to not spill water through out the area. Good Luck
Dave
Aug 25, 2009 | GE AJCQ08ACB Air Conditioner
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
After i've turned on my computer, and used it for about 5 to 10 minutes, the computer freezes and i have to turn the computer off. when my computer freezes my mouse usually does not freeze. sometimes i'll...
You can start by uninstalling the program you installed before this started happening. You can also do system restore which you'll find in start>accessories>system tools.
If nogo, try disconnecting devices on the back of the computer except the keyboard, mouse, monitor and power. Turn the computer on without them. If the issue disappeared, reconnect what you unplugged one at a time until you find the culprit.
Nov 05, 2008 | Computers & Internet
Shutting off
i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
Apr 22, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion zd8000 Notebook Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
