Question about Electrical Supplies
I have a slide dimmer switch The orange light on the switch plate is flickering, when slid down in the off position?
  • 1 more comment
  • Anonymous Feb 28, 2009
    Thanks for the response, The dimmer was installed approx. 1 yr ago. The little orange light on the plate flickers and just want to make sure it won't affect the actual wire connections and cause a short... hopefully, if it burns out, it won't harm anything?
  • Dan Todd May 11, 2010
    Do you have it connected to a fluorescent bulb?
  • Terry Lee
    Terry Lee May 11, 2010
    How long have you been using this dimmer before the problem occurs? Or is this a new dimmer? If it is an old dimmer, the dimmer coil could be leaking and need a change.
    President:
  • 704 Answers
This is caused by the neon bulb that is used in most slide dimmer switches, it is normal and doesn't mean anything is wrong with your dimmer. The flickering is because the neon bulb doesn't have the usual filament, but used neon gas to cause the light to glow.
The bulb is used as a locater light for nightime so you can more easily find the switch in the dark. When the light switch is turned on, the neon bulb typically isn't lit.
Hope you find this Very Helpful and best regards!
PS: I just came across this unanswered question and decided to provide an answer to clear this unsolved question from the site.
Posted on Sep 10, 2009
Lights flicker in circuit with dimmer switch
Dimmer gone bad.
Buy new dimmer.
Check total wattage of bulbs, and compare with watt rating of dimmer.
Check if dimmer feels warm
reduce watts in ceiling linghts
http://waterheatertimer.org/How-to-wire-3-way-dimmer.html
Gene
h
Jun 26, 2013 | Electrical Supplies
How to shut off headlights
Slide the twilight button, or dimmer button all the way down once it's slid all the way down then push it down once and your lights should go off.
May 19, 2013 | 2002 Buick LeSabre
Dome/interior lights on my 1991 Dodge Grand Caravan come on in Dimmer Position for Dash Lights
Replace the switch The age of your vehicle warrants the switch replacement
May 29, 2017 | 1991 Dodge Grand Caravan
Dodge ram headlights wont work unless dimmer switch pushed
Could be the headlight switch or the dimmer switch.
I would check for voltage at the dimmer switch first.
Sep 17, 2012 | Dodge Cars & Trucks
Hello - I have just installed two Lutron eco-dimmers in my kitchen.They work expect that the on/off switch is reversed and yet the dimmer toggler is working correctly: slid up it's on and slide down and it...
Double check the model number - is it a TG-600PH or a TG-603PH?
If its a TG-603PH, and this is part of a 3-way circuit (there's another light switch that turns the lights those same lights on & off), then this is normal. If you flick the other light switch, you'll then see that the dimmer works like it should. This has always been the case with 3-way switches, up doesn't necessarily mean "on" and vice-versa.
If its a TG-603PH, and this is part of a single-pole circuit (this is the only light switch for those lights), then the product is miswired, and upside-down. To fix the miswire, look at the screws on the back of the unit (ignore the green grounding screw for the time being), two of those screws are made of the same material (same color), and only one of them should have an electrical wire going to it. Take that wire out and put it on the other screw of the same color. That fixes the miswire. Then when you re-install the device, flip it upside-down from what it was before.
If its DEFINATELY a single-pole, TG-600PH, then call their tech support center at 1-800-523-9466 - because that makes absolutely no sense.
Nov 28, 2010 | Lutron TG600PHWH Toggler 600W Preset...
After installing a new sliding dimmer switch -- the dimming portion seems to work fine, however the off portion when slid down does not turn off lights?
It sounds as though the switch is faulty. Try replacing it and see if that does it. Hope this helps. Good luck.
Dec 02, 2009 | Electrical Supplies
I have a pioneer keh-p5450. can please send me a wiring diagram for this unit?
Here is the breakdown of what wire does what:
+Red..............12v ignition
-Black............Ground
+Blue.............Power antenna
+Blue/white.......Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
+White............Front left positive
-White/black......Front left negative
+Grey.............Front right positive
-Grey/black.......Front right negative
+Green............Rear left positive
-Green/black......Rear left negative
+Purple...........Rear right positive
-Purple/black.....Rear right negative
Oct 05, 2009 | Pioneer Car Audio & Video
Leviton slide dimmer switch w/locator light light comes on but doesnt dim
What sort of light is it , dimmer switches normally only work on Incandescent type lights not flourescent type.
Otherwise it sounds as if the dimmer function is faulty.
Nov 02, 2008 | Leviton Decora Light Dimmer Switch
Overhead lights
check you dimmer switch. the dimmer switch is what controlles the interior dash lights and dome lights. you might have acidently hit the switch and it may have pushed it up from the position it was at. if you push the switch all they up than you interior light will come one even if you shut the car off and pull the key. turn the dimmer switch all the way down and see if it still does it. if not than wait until it gets dark and go outside and turn the swich up until ou can see the dash lights. but remember if you turn it up to far the interior lights will come on.
Aug 01, 2008 | 2004 Pontiac Montana
Electrical Supplies Logo
847 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
