Question about Insignia IS-DVD1001 DVD Recorder/VCR
Have sound but no picture
My insignia 42" LCD has sound but no picture has been fine for a month its connected to a digital dvr/cable box. How do i get the picture back
    Problem Solver:
  • 4 Answers
I would check the connections to make sure they are good. The video connection could have gotten knocked loose. Sometimes they just come loose.
Posted on Mar 19, 2009
  • Karen
    Karen May 15, 2014
    Where do I look
Digital noise when using ANY HDMI inputs or cables on Insignia 37" LCD TV
Most of the time it will involve replacing the entire board that connects to the HDMI and outputs associated with it--not a cheap fix and good luck finding any board for this brand set.
May 25, 2012 | Televison & Video
Insignia 42 lcd hdtv purple pink screen
If DVD input works likely a issue with the signal.
If using a cable or sat box or even a receiver inline--unplug each and after several minutes plug back up to allow each unit to try to reboot.
If using component connections from box or receiver they may be the issue or not. In that case if a box is feeding signal via component or even HDMI the box (if reboot does not fix this) may be bad.
Another simple test if cable is used with a box is disconnect cable going to the box and connect directly to set--that way you will know if box is or is not the problem.
May 22, 2012 | Insignia 42" LCD Flat-Panel HDTV
Have Philips 42" with sound but no picture. Any guesses
You have problems with your inverters. Inverters will light the screen. In your case I believe this will solve your problem!......But in the event you moved your cable connections to install a DVR or satellite box or high def box, See if you may have improperly misplugged the yellow cable. A common fault by do it your selfers! Please check this before you see a TV tech!
May 11, 2010 | Philips 42PFL5332D 42 in. LCD Television
Surround sound signal not transferring.
need to go into audio menu and select digital audio as the output signal, its probably set to mts stereo.
Aug 29, 2009 | Insignia 42" LCD Flat-Panel HDTV
No picture or response - LG LCD TV
Hi, I have the exact same problem. I was wondering if you could tell me how you fixed it? Mine is only 2 hours old from the box
Jun 03, 2009 | LG 42LG30 42 in. LCD HDTV
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Insignia IS-DVD1001 DVD Recorder/VCR Logo
146 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
