Question about Frigidaire ATF6000ES Front Load Washer
Washer will not empty water, wife washed backing came off
This is a new front load washer, wifey was washing a throw rug and the backing came off. Now it will not spin the water out. Where do you suppose this thing is plugged up at???
  • 265 Answers
Dont blame the wife lol
Posted on Feb 25, 2009
    Genius:
  • 2,920 Answers
In the pump its at the bottom of the machine and where the drain hose hooks up. youll have to tilt the machine to get to it
Washing machine, model #WA45M7050AW/A4, wash throw rugs. There is no information in the manual which came with the machine. Is there any information one might find useful when washing a rug?
like a bedspread throw rug, rather than a rug for the floor?
Same as the material it is made from, normally cotton. Cold wash, minimum agitation, medium spin. You may need to re-balance the load after washing as it is a top loader.
WA7050 4 5 cu ft Top Load Washer Washers WA45M7050AW A4 Samsung US
Mar 18, 2018 | The Computers & Internet
Throw rugs are dripping wet after washing. My washer doesn't have just a spin cycle, so I have to rinse and spin. This still doesn't help. Every rug I wash comes out dripping.
The washer is likely detecting an off balance load with only a rug or two. You may want to try and put more rugs or old towles in to offer a counter balance to alleviate off balance condition. Or, you may consider washing the rugs at a commercial facility. They really are hard on the residential machines, especially if they come apart or the backing comes off.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi..we washed a rubber backed rug and the rubber came off and the water will not fully drain. we washed several empty cycles since with no results
You will have to take the hoses off between the tub and pump, and the pump and weall drain. They are packed with rubber. Oh, don't forget to clean the inside of the pump too. Run clean water through all hoses and the pump before reinstalling and you should be fine. Don't wash rubber backed rugs in washers unless you go to the laundry mat. This should be put in the maintenance guide of your washer book, but I've yet to see it.
Feb 03, 2010 | Malber P21 Front Load Washer
My wife was washing some throw rugs in the HE5t and one of them fell apart in the wash. Clogged up the filter and will not drain. Door is locked so I can't get inside to clean filter and washer. How do I...
hello, You should remove the lower panel at the front of the machine, behind there you will find what looks like a gas cap from a car right next to the pump, unscrew the cap making sure you have plenty of towels handy and remove the filter...empty the water out and clean the filter...re-install the filter trap and you should now be able to open the door. Don't forget to unplug the machine before servicing. Hope this helps, thanks for using fixya..good luck . Mike
Aug 06, 2009 | Washing Machines
After a wash cycle, the letters UE appeared in the timer window..
UE = Unbalance error.
try to use a low spin speed with loads like rugs, and try to get as even a load as possible. (ie: not just one rug) Don't wash rubber backed rugs, as the backing can break up and clog your machine.
Now, if you are successful washing with the lowest spin speed, you can hold the " Spin Speed " button in while pressing on the power button. Release power button. Now release the spin speed button. Now, press the spin speed button until the next higher spin speed from your last successful spin. Press start. Your washer should now pump out and attempt to reach the new spin speed, without adding any water. (usually about a 14 minute pump and spin cycle) Don't expect to be able to spin out rugs at a high spin speed.
Jul 05, 2009 | LG WM2487H Front Load Washer
Washer will not start washing cycle. Machine hums like the dryer
Check the drain for clog. If the drain is dirty, the washer won't fill, rinse, or drain.
May 23, 2009 | Frigidaire ATF6000ES Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
90 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
