Question about Brother MFC-8460N All-In-One Printer
My Brother MFC 8460N won't scan -
When I scan something it scans it from the network Brother 8460N not the one sitting right next to me. I can print directly from my computer to my printer, but when I need to scan something I have to walk into another room, put the document in, walk back to my desk, click scan, then walk back to the other office to retrieve the document.
A real pain seeing as how lazy I am...
SOURCE: document jam brother mfc 8460n
if the message refers to the scanner, open the cover of the feeding unit on top of the printer and clean it with compressed air. Most probably an insect got stuck somewhere
Posted on Nov 07, 2008
jtuminaro
  • 56 Answers
SOURCE: Need to reset 'Drum near end' warning on Brother MFC-8460N.
Open the front door
Press clear
then press 1
Posted on Jan 15, 2009
commtech
  • 13 Answers
SOURCE: How to Change Brother MFC 8460N Drum
Pull open front cover at left/right sides. Then press the button at top/middle of next cover and pull it forward and down. Everything else you need to do to change the toner is shown graphically on a sticker at the rear of this cover. Follow the pictures from left to right and you will be done!
Posted on Jun 14, 2009
anjana03
  • 361 Answers
SOURCE: brother mfc-8460n prints black streaks
ithink . brother printer is best, we can always reffil untial drum isnot scarch, some time drum life is endinging as u say iit can be reset . after this we get 100% life. there is no need cheap and tools for reset it. reffiling before we reset cartage by adjusting cartage sides white ring. and we can also reset reffiling after . this treak is secre to tech.
Posted on Jun 18, 2009
prashanthcl
  • 460 Answers
SOURCE: Three dots on right hand side
pls replace the toner because it is a toner problem.
Posted on Sep 17, 2009
I have installed mfc 8460n driver. printer, fax, copier are working well. scanner installed but not working. it says error... what is the problum?
is it telling - Error communicating with scanning device?
Which operating system do you have?
How is it connected - USB or Ethernet?
Which Anti Virus program do you have?
try to disable your anti virus and scan
Please reply so that I can assist you further
Apr 19, 2011 | Brother MFC-8460N All-In-One Printer
How can I print from the top of my brother printer
Hi
You cannot print from the top feed,
The use of the top paper feeder is the capability to make single or multiple photocopies and for single scanning or multiple scanning. All you have to do is to put single or multiple document in the top feeder and press the COPY BUTTON (third button-right side). Then it will feeds automatically.
The same with scanning, press the SCAN BUTTON (first button-left side) and it will scan single or multiple document.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 10, 2011 | Brother MFC-8460N Laser Printer
Brother MFC-8460N network printing, local scanning
Yes this is possible. Depending on the type of installation that has been done on the computer, you can even scan documents to your computer as a network scanner.
You can check and see if all the features have been installed on your computer. Click on start, all programs, and look for the folder called brother. If you can find brother you can look for the sub category for Conrtrol Center. From Control Center you can scan by clicking on one of the icons. Like file or image.
If none of this is installed, get your installation disk and install the software, you can do a network installation or a Local (USB) installation.
If you decide to do a Local installtion remember to only plug in the USB cable when promted to.
If you decide to do a network installation, the machine should already be installed on the network, which I assume it is since its being used as a network Printer.
Please let me know if any of this info was usefull, and if you require more info about this.
Apr 12, 2010 | Brother MFC-8460N All-In-One Printer
Now that I have Windows 7, when I scan my Brother 8460n does not give me to option to scan to Microsoft Word or Adobe. How can I fix this?
Check latest windows 7 compatible driver and download and re install..
http://welcome.solutions.brother.com/BSC/public/us/ca/en/model_top/monolasermfc/mfc8460n_all.html?reg=us&c=ca&lang=en&prod=mfc8460n_all
Feb 11, 2010 | Brother MFC-8460N Laser Printer
SCANNING A DOCUMENT
the easiest way to scan a 20mpage doc or more is to opeb the paper port icon and then follow the prompts, this is easier then scanning from the printer good luck brother sr tech
Jan 12, 2009 | Brother MFC-8460N All-In-One Printer
Printing problems
If it is approx 3-4 smudges down the page. Replace the drum cartridge.
Oct 30, 2008 | Brother MFC-8460N Laser Printer
MFC-440CN: Prints but does not scan
Go to system/computer control panel, select "scanners and cameras". you should see your brother system in there (if u were able to print to it but not scan). Right click on it, select properties, and select "Network Properties" Tab. Choose select "specify your machine by address" rather by "by name". Most home/home office users dont have a local domain server at home, so even though your printer was named, it cannot be located by tcp-ip using the name, but rather by ipaddress. This solves the issue.
Feb 02, 2008 | Brother MultiFunction Center MFC-440CN...
Scanning with the MCF-8460N
i just download sp3 in my computer and trying t scan and e-mail it does not work now
Dec 13, 2007 | Brother MFC-8460N All-In-One Printer
Brother MFC-8460N All-In-One Printer Logo
1,158 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
