UTStarcom PCS1400 Cellular Phone Logo
Posted on Feb 25, 2009
I can't get my phone off vibrate.
There is a picture of a phone with an "E" in the right corner. We have tried going to setting and adjusting the settings, also from the side of the phone. Neither work. If you try to set a ringtone, it will tell you to "change the sound mode before you play your ringtone" but changing the setting on the ringer doesn't do anything! Help!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
500
Points
Cant get virgin phone off vibrate
Galaxy how to delete
If it's from the Galaxy family, just go to the picture that you want to delete and tap and hold for some 3 to 5 second, it should vibrate (if vibration is on) and allow you to delete the picture. Within the galley, you can choose various pictures at the same time to delete. If you opt to delete from the gallery, once you have chosen the pictures, notice at the top right corner should be some icons, one of them is the delete icon. Not all galaxy are the same, so I'm trying to explain as clear as I can the way I would do in my Galaxy S2.
Mar 11, 2014 • Cell Phones
1helpful
8answers
Samsung u700 mobile phone vibration mode is not working
go to menu , then select settings ,then go to factory default setting,then it will reset,turn off for one minute then turn on again,then go to vibration setting ,then test if vibrating.if not the dynamo of vibration is defected a factory defects,just try this option...
tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
1helpful
What does the mobile phone picture mean in the top right hand corner of my screen
That symbol usually means your phone is on vibrate. Try turning it off of vibrate and seeing if it disappears. I hope this helps!
- Frankie
1helpful
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Photos have a black corner. Sometimes upper right, sometimes lower right. The black corner covers approximately 5% of the width and height of the image. Can I fix this myself?
This might also come from a problem with a dealignment of one of he servo-motors (horizontal or vertical) which center the lens during anti-shake adjustment.
If your camera vibraets at start or shows a vibrating image on display then this is the problem.
Then the lens is often out of axis and black corners appear on the display and of course on the picture...
I have not found the solution but have posted a request !
It may only be some disconnected part near the lens but unfortunately nobody shows pictures of HOW to dismantle the Z5 ! and WHERE are these 'bloddy' servo-motors or alignment devices ?...
No Voice
two things you can try.
1: go to tools settings and adjust the volume that way
2: tools settings voice settings and if nothing is selected in the top right corner you can select a voice there
hope that helps
How to set my phone to vibrate only
On the main Home screen, go to the speaker icon in the upper left corner (right below the battery gauge) and click it. Then choose "vibrate only" from the list of sound profiles.
5helpful
8answers
Nikon Coolpix p80 blacked out, rounded corners
Have you attached some sort of lens shade to the front of the lens? The vibration might have something to do with the shake reduction system but I can't be sure. It certainly shouldn't vibrate heavily. You might get a better answer if you e-mail the tech guys at the support section of the Nikon website.
50helpful
4answers
SCH-R450 How to deactivate silent mode???
Keep holding down for 3 seconds the (#) Buttom. And it's fix.
Top UTStarcom Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
