Question about Sharper Image (CT411) Consumer Headphones
Sharper Image CT411 head set batteries?
How do you change the batteries?
  • 3 Answers
You peal off the soft part of the headphones that cover your ear you'll see the battery compartment from there
Posted on Nov 25, 2009
How do you connect the wires to the tv
you have to get adapter cables. Check with Best Buy, they'll be able to get you the right cables/adapters
Jan 09, 2011 | Sharper Image (CT411) Consumer Headphones
How do I take apart the headset speakers to get to the wires inside?
See my tip on replacing dodgy cable/plugs on headphone, it has information on opening up headphones.
Sep 01, 2010 | Sharper Image (CT411) Consumer Headphones
Left side of my sharper image ct411 doesn't work at all.
Check your cable and make sure there aren't any frayed or cut wires. If your cable looks good, then open up your headphones and make sure the connection to each speaker is correctly soldered. Sometimes when you expand/contract the size setting on these headphones it pulls the wire until it eventually disconnects. I hope this helps!
Aug 31, 2010 | Sharper Image (CT411) Consumer Headphones
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
Sharper Image Alarm Clock won't reset after changing battery
  • https://www.sharperimage.com/si/pdf/manuals/204050.pdf
Jan 06, 2018 | Audio Players & Recorders
Earpiece broke off
Search online for the makers website. You can then contact them about it. You will need to prove the date of purchase and which seller on E-Bay you got them from.
Nov 11, 2017 | Sharper Image (CT411) Consumer Headphones
Batteries
You need to remove the rubber on each side of the headset - and you will need to replace one "AAA" battery on each side - hope this helps
Aug 25, 2008 | Sharper Image (CT411) Consumer Headphones
My headphones won't charge.
Remove the rubber caps and replace the two AAA rechargable Ni-MH batteries.
Aug 15, 2007 | Sharper Image (CT411) Consumer Headphones
Sharper Image (CT411) Consumer Headphones Logo
530 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
Tom Chichester
Yoav Shilon
Yoav Shilon
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
