Question about Whirlpool Refrigerators
Whirlpool refrigerator doesn't defrost model et18tkxjwoo
It go's on & off & runs good keeps every thing cold but when it get ice up it will run all the time check pan for water it is dry.had some one look at it said unplug it and it will be all right pay him and it is doing the same thing can you help johnb19@netzero.net
  • 25 Answers
Your defrost clock or the defrost element. Check the clock first. A new one is about $30.00
Posted on Feb 25, 2009
My Whirlpool Refrigerator/Freezer Model #GR2FHTXVQ00 or GR2FHTXVO00 is not keeping food cold. Food is spoiling. Freezer is cold but Refrigerator is warm.
With signs of freezing up in freezer area that would indicate a problem with the defrost components. The most likely reason would be a defrost control board. 2304093 Defrost Control Board
Here is a link to a parts manual for your model=> GR2FHTXVQ00.pdf(1101.27 KB) Look on page 3 and part location 4 That is the=> 2304093 Defrost Control BoardThe next possible parts are the 2314157 Defrost Heater Assembly found as item location 4 on page 9 of the PDF. It may be a good idea to change the defrost thermostat=> 2321800 Defrost Thermostat found on page 3 with item location 28. If you have questions please let me know, Thanks John TrippAppliance 911
Contact Me Here
Sep 23, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a GE model GSS22JERFWW S/N AL243114.The freezer portion doesn't freeze the ice trays and the refrigerator portion doesnt keep anything cold as it should even tuned up to 9 whereas it used to...
Things to check: does the compressor run? Does the fan close to the compressor run? Does the inside fan run? Is the rear wall inside the freezer covered with frost? That would indicate that it is not going into defrost which will have the same result (no air movement). Does this help?
May 20, 2011 | GE Refrigerators
Whirlpool refrigerator type 21TFA refrigerator won't cool - air vent in freezer keeps icing up
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
The refrigerator keeps icing up at the bottom parts. foods are turning into ice . It is not turned up very high on the dial.
heatman101
Jan 04, 2011 | Whirlpool Refrigerators
Refrigerator is not getting cold
fan motor running in freezer?- put unit in defrost the timer has a slotted set screw turn clockwise the unit will go into defrost the electric heater will start/ the fan in freezer and compressor will stop do a few times to get rid of ice if does not go into defrost a couple of things maybe wrong the first thing to check is fan motor in freezer should be running if not everthing will freeze
Jan 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Fridge not cooling
Aug 10, 2009 | Refrigerators
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer and refrigerator will not get cold - fan runs but not ver
You will need to check for frost accumulation in the freezer section. The rear panel inside the freezer will need to be removed. If there is frost either the defrost bi metal or the heater are open. If both are ok the defrost control needs to be replaced depending on the model some defrost controls are electronic some are mechanical.
Dec 26, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
91 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
