Question about E-Machines eMachines Desktop PC
Blinking on and off
My emachine t2042 is hooked up right but, when i out the power cable in it the computer and keyboard blink on and off. It also makes this annoying sound and the cpu fan doesnt rotate. Can someone help me with this?
    Novelist:
    Scholar:
  • 72 Answers
No offense, Tyson, but would you mind explaining your question a bit better? You wrote "when i out the power cable in it"and that really confuses me. Did you unplug the power cable or did you plug it in?
Also, how long ago did this happen? Was there anything you can think of that may have caused this problem?
If the CPU fan is not rotating, you may have a problem with your power supply.
I am guessing your system is powering on, but not showing anything on the monitor.
Try removing every thing from the computer, starting with the power cable. Then add back only the monitor and turn it back on. If it works, one of the items you left unplugged is causing a problem.
If that does not work, again remove the power cable and open the case. Remove all expansion cards other than video, disconnect all of the drive power and data cables (CD, DVD, hard drive, etc.) then plug in only power and monitor to see if you get anything.
If still no go, unplug power cable, carefully remove the RAM and put it exactly back where it came from. At this point, if you still get nothing you are down to 4 components:
motherboard
power supply
CPU
video card
If the CPU fan is still not spinning, I would suspect it is the motherboard or power supply. Get a can of air and blow out the CPU fan to make sure it rotates easily.
Let me know if you need more help.
Honest1abe
Posted on Feb 25, 2009
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Emachines t2042
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted,but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static ChargeBuildup. Remove the Power Cord, then Press and Hold the power button for30 seconds. After 30 seconds plug the power cord back in and hit thepower button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Jun 07, 2012 | E-Machines eMachines Desktop PC
T2042 emachines audio problems
It's easy to fix this problem.
Stop using the audio chipset on the motherboard, and install a Sound Card.
They are economical, and will surpass the audio quality of that eMachines motherboard, by a mile.
The eMachines T2042 Desktop PC, uses one of these TriGem Imperial motherboards,
http://www.e4allupgraders.info/dir1/motherboards/socket478/imperial.shtml
Scrolling down you can see the audio is AC'97.
Not worth writing home to Mom about.
The Sound Card you obtain will go into one of those long white PCI slots.
(There are 3)
Any available PCI slot that is open, with no adapter card in it.
Here is but one example of a sound card that will work,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=420797&CatId=2771
Need guidance in installing? Post in a Comment.
[ Remember to follow Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out, (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE working on your computer.
Computer on a table, computer Unplugged from power, computer case open.
TOUCH an unpainted surface of the metal frame, of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be
SURE to Touch the metal frame again upon your return ]
May 20, 2012 | E-Machines T2042 PC Desktop
What is the best replacement for my T2042 computer.
It all depends on what you are looking for. If you are looking for a Gaming desktop then I'd recommend Alienware If your looking for producing and editing videos I'd recommend an HP or Sony possibly Mac. For an all around PC go for a Gateway, Acer, eMachine or any other lower branded computer.
Apr 26, 2010 | E-Machines T2042 PC Desktop
We get a blinking green light response where the ''On'' button is on our Compac presario SR 1111 NX and cannot get the computer to turn on. Is this a battery problem of some sort? Can I fix it? The...
take out all the cables from the back of computer,press the power button for 1 min and then plug in only keyboard,mouse,monitor and power ,it will work
Feb 09, 2010 | Computers & Internet
The computer will boot but there is not thing on
There was a proble with RAM or motherboard,
  • press the power button and see keyboard (num lock) light (right side of keyboard) is blinking thats means RAM problem in your system
if you are able to open the system,unplug the power cable and open the side cover of CPU,four slod in your system check how many RAM's in your system.if you are using two RAM's of 512MB and than remove the one RAM vis a virsa and plug the power cable than start the system,
  • press the power button and see keyboard (num lock) light (right side of keyboard) is not blinking thats means motherboard problem in your system
please go good shop and replace it.
Thanks,
Dec 16, 2009 | HP Pavilion a320n PC Desktop
T2042 E-Machine Both the power button and the hard drive light keep flashing i also noticed the lights also flash they all flash fast but never boots. The power button is flashing green along with green...
Disconnect the power cord from the back of the system. Press and hold down the power button for 10 seconds.
Disconnect everything from the back of the computer ,except keyboard, mouse and monitor.
Reconnect the power cord and then check
Thanks for using fixya
proton
Nov 07, 2009 | E-Machines eMachines Desktop PC
Have a t6532 running fine one moning blue light blinking no boot fan runs 3 seconds no noise then blue light blinks nothing runs.
UNPLUG all keyboard, mose and etc and plug only power suppl and then video cable with the cpu and then power on you can get the display in you monitor
Oct 20, 2009 | E-Machines eMachines Desktop PC
Desktop Lockup
Remove the cover to look at the power supply fan while it is powered on ( if needed). The fan should be spinning at a steady rate. If you observe fluctuations in the rotation, these are early indications of a malfunctioning power supply unit. As for the knocking sound, can you hear it better or determine its source if the cover is removed? It could be the fan hitting the side of the power supply or wiring. The good news is that if it IS the power supply, they are relatively inexpensive and easy to replace. Your sister may not be out of luck!
But if the light is blinking- and orange - this is definite indicator that the power supply is going. Still a good idea to replace the p/s unit and let her use it. With RAM being as cheap as it is, I'd also recommend bumping it up to 512 minimum if not a 1 GB.
Jan 08, 2009 | E-Machines T2042 CELERON 2 GHz 128 MB 40...
EMachine Model T3828 No power
Hi there
Thanks for posting your problem on fixya
Please check your all the cables first its plugged properly or not then try to open the computer and
check the keyboard light is it blinking or not. check the cpu its making any sound or beeps. Please take
out your pc at nearest hardware shop its a hardware problem. Maybe issue with the ram or smps power or battery supply please
Thanks
Robert
Sep 20, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
111 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
