Question about Yamaha MX-D1 2-Channel Amplifier
Yamaha rx-797 w/Yamaha ge-60 eq utilizing prein/main out ..and ad
I have a Yamaha rx797 reciever with a Yamaha ge60 eq hooked thru the pre in and main out couplers....and want to add a Yamaha mx-1 power amp which would normally be hooked up via the pre out(reciever) to the main in (amp)....what is your recomendation?
  • 4,234 Answers
It sounds like you want to use the external amp rather than the internal one. If that is the case, just connect the output of the EQ to the input of the external amp. All you are doing is inserting the EQ between the amp stages now. Using the mx-1 rather than the internal amp is no different.
Dan
Posted on Feb 25, 2009
I have an rx-v1000 w/ an adc equalizer ran in and out of the amp w/ a couple of splitters coming out of the eq and it seems to work great. I have even thought about splitting it again to run an m-80. My goal is to run 2 12'' on my m70, 2 15'' on the m-80 and 2 8'' on my stereo receiver. I have this set up half way and wouldn't mind any feedback from some experts out there.
Posted on Sep 03, 2010
How do I connect my 901 equalizer /speakers to the yamaha rx-v633 receiver?
Sorry, it doesnt look like you can hook up an external EQ while still using the amplifier section of the yamaha. Instead, You would have to use the preamp out to go to 901 EQ, out of the EQ into another stereo amplifier, then to the 901 speakers. Personally, to power the 901's properly, I'd use another external amplifier. You will barley get 75watts per channel out of the receiver to power the 901's
Jan 03, 2015 | Yamaha Av Reciever Rx-v793 Cinema Dsp...
I am using the "
http://www.retrevo.com/support/Yamaha-RX-797-Receivers-manual/id/320ag612/t/2/
I assume you've placed the Bose Active EQ in where the Pre-Out >> Main In jumpers were. Do you have the return from the Bose Active EQ going back into the Main In so it can continue to the Sub Output.
Or do you have the Bose EQ Tape Switch activated incorrectly?
Feb 03, 2011 | Yamaha RX-797 Receiver
I recently bought the yamaha rx-v567 and I own a yamaha EQ-70. How do I configure and hook up the EQ to the receiver?
The EQ is connected via one of the Tape loops on the amp (rec out from EQ to play in on amp,rec out on amp to play in on EQ). You then switch "Tape Monitor" on to hear the sound with the EQ settings applied. You can also connect it across Pre out and Main in should you have such sockets. I'm pretty sure it will only affect the main two front channels and not the surround channels.
Dec 19, 2010 | Yamaha EQ-70 Home Equalizer
Want to use Yamaha rx-797 reciever with bose 901 and bose 301. Yamaha says tape monitor kills digital input signals. Also sya digital inputs are the optical jacks, RCA inputs are analog, but 797 does not...
I don't know why the comment from Yamaha about Tape Monitor killing digital inputs is relevant.
According to the manal I downloaded, THIS stereo receiver doesn't have digital inputs.
As to using 901's and 301's...
You will need a separate Power Amp for either the 901's or the 301's. Sorry, but you can't share the amp with the Active-Equalized signal and non-901's.
I use 901's and 301's in MY 7.1 rig with a separate amp for the 901 and NOT using a Tape Monitor, but a preamp out feed for the front channels.
Feb 15, 2010 | Yamaha RX-797 Receiver
I have a Yamaha RX-797 reciever and wish to install an outdoor speaker system through the zone2 outlet. Do you know if I can go from the zone2 outlet through the coupler jacks to the speakers so I can...
Hello sounds like you want to take the low level zone 2 output and run it to the PRE AMP in?
If that is correct the onboard amplifier will power your speakers but will no longer provide sound for your main channel as you are removing the "loop" which send the front L & R signal to the amp.
Your best bet is to find an inexpensive secondary amplifier.
Sonance makes a sonamp 260 or 260x3. These are available on ebay for under $100 and work great for multiroom applications.
A 260x3 would give you 3 speaker outputs allowing you to run not only to your patio but also to two other locations and includes a switch to turn each zone on/ off.
Hope that helps
Jan 02, 2010 | Yamaha RX-797 Receiver
I am looking to upgrade my receiver to an audio video receiver that will hook up to a blue ray via HDMI. I want to use my 901's forthe front speakers. Can you recommend a mid priced (<$600) AVR that...
Good day,
Congrats on your new AV receiver. I own an awesome Yamaha mid-priced AV surround sound system with HDMI, BR disc player, and all that stuff. However, I'm old school and use my 901 Series Vs with a Yamaha RX-797 'two-channel' receiver. To get to the point, I have some bad news. Mid-priced (mp) AVRs, or any AVR for that matter, will not work with 901s because the active equalizer (EQ) requires either a 'tape monitor loop' or 'pre-out / main-in' connection to work properly. You've probably been told the 'why they won't work' by now and it is very true--I know from experience. Most of today's AVRs do not include a 'tape monitor loop' or 'pre-out/main-in connection for the EQ connection, thus, killing all hopes of using 901s. I truly love my 901 Series Vs (since 1985 and still kicking) and love true 'stereo' for playing my music. Again, 901s are useless with today's AVR equipment (as I know it). Just don't let your 901s collect dust--they are truly marvels!! Go with a set of good 'standard' speakers for the AVR system and buy yourself a decent stereo receiver or amp for the 901s--that's how I do it!! I've tried Onkyo, Rotel, Sansui, Poineer amps / receivers--all of them. I can tell you this--for the common, working man/woman, nothing, I mean nothing available can match-up with Bose 901s like a Yamaha RX-797 (200W)--not to mention the sound quality-wow!!! And this unit is very reasonably priced for such awesome performance and high quality build. Just know that all is not lost. You can still use your 901s--I cna't listen to music without mine.
Aug 24, 2009 | Bose 901 VI Main / Stereo Speaker
Can I hookup a Bose 901 EQ to my receiver and amp?
Your instincts are correct. In fact, the only way the 901's can live in an A/V system is with dedicated amplification.
Put that old amp back to work.
This is exactly how mine are connected.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Aug 19, 2009 | Bose 901 VI Main / Stereo Speaker
How do I connect my Yamaha EQ-70 to my Yamaha RX-V2400 receiver?
from your receiver; R&L PRE OUT to R&L LINE IN of Equalizer.
And - from Equalizer R&L LINE OUT to Receiver MAIN IN.
http://www.yamaha.com/yec/customer/hookupdiagram.html?CTID=5010070.
Hope this helps!
Aug 10, 2009 | Yamaha EQ-70 Home Equalizer
Bose 901 equalizer
Hi Mark, had a look for a manual on your Yamaha, but not got to one as yet. Does it have any RCA connections on the back marked as preout prein? best place to put the 901 EQ is in line with L and R front channels at this preout prein point.
Some amps DO NOT HAVE IT. If our does not, then you could connect it in the tape loop, tape out(rec) to input on the EQ. and the output of the EQ connected to tape in(play), but connected like this, the EQ would affect the tone across all channels(unless you are just running a stereo rig, then this way works great!!) Try this and you may just have solved you problem anyway.
regards
Graeme
Mar 28, 2008 | Audio Players & Recorders
How do i connect the bose 901 system to my yamaha rx-v2700
how about you connect your pre-amp out to eq-in and eq-out to aux ?
Mar 07, 2008 | Bose 901 VI Main / Stereo Speaker
Yamaha MX-D1 2-Channel Amplifier Logo
1,015 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
