Question about Venturer STS-35S System
I have a STS21-S system and I can not get the TV sound to come thru the system speakers. I do not have the manuel only thr quick set up paper
Vibration through speakers on my jvc home cinema system
try tightening the screws on the cabinets or buy a full set of
Wharfedale Modus Cube Main Stereo Speakers to replace the bad ones
Mar 23, 2014 | JVC Audio Players & Recorders
I had the 7 blinking lights problem. Replaced 2
Do a tv system over haul reset.Tries unplug,replug the tv an hour later.Go to the tv menu,goto AUDIO,go down to do the resetting,now the tv is back to factory setting.Go to the tv menu,than goto PICTURE,go down to resetting,to reset all the Tuner board setting,back to the factory setting.The audio,should be back now.Not,retraced from the speakers,wires back to the board connections,unplug,replug every connnetoins and replaced all the supporting components near the speakers wires are connected.
Jul 22, 2010 | Philips 42PF9631D 42 in. Plasma Television
Need owner manuel for koss KS5190 digital home theatre system
me too help bzaggy@bellsouth.net Do u need remote to set speakers along with other setting problems including, back speakers not working, tv not on surround sound, can play dvd and tuner still no back speakers, no remote. Do u need remote to set, please help!!!! email bzaggy@bellsouth.net
May 11, 2010 | Koss Audio Players & Recorders
L46wd22yx5 rca tv lost sound thru tv speakers, sound works thru home theater system...? no other problems seen...
Verify first in the audio setup on screen menu that the speakers are not set to OFF. Otherwise you may have bad power amp sections.
Nov 02, 2009 | RCA L46WD22 Television
NO SOUND FROM TV THROUGH THE SOUND SYSTEM SPEAKERS
All you need to do is follow the following directions on your TV and you will be on your way listening to your great Philips TV on your great Sony Surround Sound. You do not need to buy any other cords or anything else. Its just a setting on your TV that needs to be adjusted.
By the way, I have a Sony Home Thearte System DAV-HDX275 and I've had it for almost 8 months and its sounds good with my TV and Movies. The speakers are very cheap and it doesn't give you the sound you expect. So I came accross some Boston Accustics CR65's that are not sold anymore but they did run around $700 a peice. I am upgrading the Reciever very soon to a better qualtiy Reciever. This Surround Sound System is great for a starter Surround Sound System.
  1. Press MENU on the remote control and select TV settings >
  2. Press up or down to highlight a sound setting and press right to select the setting.
  3. Press up or down to adjust the setting, and press OK to confirm the change.
  4. Press Menu to exit.
You want to pick Incredible Surround, but if that does not work try them all. The Incredible Surround should do the trick because that switches it from the TV Speakers to the Surround Sound.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Have a Great One!
Mar 13, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sound works thru the wireless headphones, but not thru speakers?
go over all speaker connections and ensure they are good and also plugged in to the head unit and that the wires didn't fall out during install.
Jan 18, 2009 | Myron & Davis AD212
Video/dvd/cd play but no sound from speakers
Try changing "audio" setup in your TV to "variable" instead of "fixed", if you have that option on your TV set up... I have a Sony HD widescreen, and that worked for me...
Feb 16, 2008 | Audio Players & Recorders
No sound
you may have a blown fuse. check that first. Very if it still has a power.
Sep 12, 2007 | KLH SE-6000 System
Venturer STS-35S System Logo
64 people viewed this question
Top Venturer Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Venturer Audio Player and Recorder Expert? Answer questions, earn points and help others
