Question about Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV
1999 400 Polaris will not start
Cranks over but no spark - battery is good. Put new ignition coil on but still does not start.
I have a 1994 polaris 400 4x4 i cant get it to start i checked the spark i had non.. so i changed th coil then had spark cranked it over a few times now i have no spark again ....i get one spark in the off position thats it .hope some one can help me email addy is if any one knows how to troubleshoot this problem ..
Posted on Aug 24, 2010
I have similar problem. did you ever get it fixed? please let me know. thank you...
Posted on Aug 07, 2009
How do i fix my 2002 buell blast that cranks over but does not have spark.
Hi, Jordan and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable free downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at Good luck and have a nice day. Thread No Spark Problem Different Than other threads!-Spark-plugs-not-getting-spark free service manual
Mar 01, 2016 | 2002 Buell Blast
I have a 97 tahoe 5.7 4wd i am getting no park at all i have replaced, ccrankshaft sensor , cam sensor, All new sparkplugs ac delco, ignition module ,ignition coil, and entire didistributor. Stil yet not...
You didn't mention the cap and rotor.
Are you getting battery voltage to the coil in the on and crank position? Are you getting a tach signal to the tachometer ?
Could be a problem with the engine computer among other things.
Feb 21, 2015 | AC Cars & Trucks
No spark from coil
charge the battery fully it may not have enough charge to start, you could jump start it with a battery or a car but not a running car, they put out 16 volts and will fry the electrics,
Jul 28, 2014 | 2011 Kymco Downtown 300i
Spark plug blew out now car wont start
sounds like the autoshutoff relay may be controls the ingition and the fuel pump too..if the pump works check for spark by inserting a screwdriver into a pulled off spark plug wire and look for a decent spark between the screwdriver shaft and any ground like the block..if no spark the relay may not be powering up the ignition system..
Dec 15, 2013 | Acura RSX Cars & Trucks
96 bronco 5.8 cranks but no fire
Did you check primary voltage to ignition coil? red wire with lite green tracer, use a test lite to check voltage, goes hot with key on, circuit is fuse protected.
Dec 25, 2017 | Ford Bronco Cars & Trucks
1989 chevy truck, 5.7...will not fire at spark plugs, Bat. voltage at ignition coil and to ignition module, tested ignition coil (OK), new distributor and rotor, no change. Used starting fluid...
Hi, I believe there is a computer problem. If possible check codes for no start condition. if you know the no.#1 cylinder at TDC (Top Dead Center) on engine then you will know no#1 distributor is. Good luck.
Jun 14, 2011 | 1989 Chevrolet C1500
Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV Logo
1,007 people viewed this question
Top Interactive Toy Concepts Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
