Question about DFI AD77 Pro Motherboard
I need the pin placement for a aspen2 motherboard
  • 203 Answers
Http://us.dfi.com.tw/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=&windowstate=normal&mode=view&downloadFlag=false&itemId=228
this link will take you to your product overview on the DFI website. you can download all manuals and technical data from there.
Posted on Feb 25, 2009
E210882 motherboard front panel pin placement
you need to find the aa number or the identifier of the model.
May 09, 2014 | E-Machines T3985 PC Desktop
Where on a Gateway DX4200 MB does the red/white wire coming from the power on switch?
You'll need to get your hands on the manual for that specific motherboard to determine where the pins are for the two Power On plugs. Lacking that, many motherboards have the pins for the entire set of front panel wires labeled--I do suggest you get a magnifying glass if you're stuck with this route, and the labeling is often not specific as to the precise placement of the plugs onto the motherboard's pins, meaning you'll sometimes have to simply trudge through the tedious process of trial-and-error.
Apr 28, 2014 | Gateway Computers & Internet
Clear password of bios
You need to clear the c-mos on the motherboard. There is a jumper that needs to be taken off the first two pins out of the three, and moved to the last two of the three pins for 5-10 seconds to be sure. However each motherboard will have different placement on where it is. I would find the manual for that motherboard in this case. Usually the jumper is located near the 3v lithium battery. You may take the battery out for few seconds as well, but that may or may not work on all motherboards. WARRING this will reset all your BIOS settings once you clear the c-mos. I do recommend you refer to the motherboard manual.
Jan 02, 2014 | Toshiba Computers & Internet
I need the front panel pin placement locations
In order to avoid possible mistakes clarify me the model of the motherboard.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Dec 12, 2010 | Intel Motherboard
What are the jumper pins on my Maxtor 6l200m0 and 6l200s0 sata drives for?
To control how the computer separates and assigns the drive's working order and placement.
The most basic positions are:
Master - By default the motherboard will boot to this drive first, therefore it's the "master"
Slave- What it sounds like. It's under the "Master" and isn't booted by default.
Cable Select (CS) - What it sounds like as well. The cable that goes from the motherboard to the hard drives. There are TWO positions at which the cable connects to the drives based on their placement. That placement determines which drive is master and which is slave. The advantage of this mode is it's ease of use. (Use only when you've got two hard drives)
That's the basics of the basics. There is A LOT more to those jumpers...but you won't ever need to know what so don't ask ;)
Let me know if you have any other questions.
Nov 22, 2009 | Maxtor Hard Drive
Pin placement for ms 6741 mb
the manual for your motherboard can be downloaded here:
http://www.msi.com/index.php?func=downloadfile&dno=3812&type=manual
On page 2-17, the pin-outs for those connectors are specified in detail. They are part of the JFP2 header:
PIN SIGNAL DESCRIPTION
1 HD_LED_P Hard disk LED pull-up
2 FP PWR/SLP MSG LED pull-up
3 HD_LED_N Hard disk active LED
4 FP PWR/SLP MSG LED pull-up
5 RST_SW_N Reset Switch low reference pull-down to GND
6 PWR_SW_P Power Switch high reference pull-up
7 RST_SW_P Reset Switch high reference pull-up
8 PWR_SW_N Power Switch low reference pull-down to GND
9 RSVD_DNU Reserved. Do not use.
-Jon
Sep 01, 2009 | MSI K8MM-ILSR (MS6741030) Motherboard
Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Apr 01, 2009 | Dell Dimension 4600 PC Desktop
ASUS A7n 266 VM Sound Problem
I think you are refering to the front audio pin that are dislodged. Refer to your user manual for the pinout diagram, If there is some other problem get back.Thanks
Sep 19, 2008 | ASUS A7N266-VM Motherboard
Wires they connect two 2 pins on motherboard
Do you have the manual of the motherboard, please mention the type, make, model, manufacturer of motherboard please this way we can help you out. Also please try to mention your question clearly.
Thanks
Dec 10, 2007 | ASUS P4C800 Deluxe Motherboard
DFI AD77 Pro Motherboard Logo
175 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
