Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Fine gritty residue on dishes, particularly on glasses
My water temperature is within the recommended temp of the detergent manufacturer. I have tried the new packet, gel, and powder types of detergent.
I have cleaned the inside of the dishwasher with Tang, and vinegar as well as checking the bottom filter for debris. I have removed the upper spray arm and cleaned this as well (nothing appeared to be in the arm).
It seems that every dishwasher I've ever had runs fine for 2-3 years and this same problem occurs after this time frame (I've had this dishwaser for approximately 3 years) no matter the brand.
  • glennda584 Mar 18, 2009
    We have the same problem. The grit is brown. It is deposited preferentially on one side of the glasses on the top rack, both inside and out, and on some bottom dishes. A repairman checked the machine, water temperature and drainages and replaced the drainage pipe, which had some of the same grit inside it. Also ran TSP through. Nothing worked. My son is running vinegar through it tonight and it made a loud grinding sound partway through the cycle, so I turned it off. He says it has made that noise before.
  • 423 Answers
Alm84, Are you using a brand name powder like Electrosol or Cascade? Try that first. Seriously, it makes a difference.
When you say your water temp is within the recommended temp for the detergent manufacturer, do you mean the water heater temp at the sink tap is 120 degrees? MOST problems with cleaning that are not caused by generic detergent or plugged filter/debris in the impeller area are caused by a failed heating element. No kidding, it makes a BIG difference and once it is repaired, you will see an immediate difference.
glenda, First try this: remove the lower spray arm and the filter and assembly. Clean everything in the sink and with a flashlight, inspect everywhere for "chunks" that is probably causing the noise.
Reassemble and test. If dishes still do not get clean, check the heating element, replace if needed.
If that does not fix the problem, you will need to replace the main wash motor/impeller.
Good Luck!
Please update me with what you both find. OK?
Posted on Apr 10, 2009
Glasses have a white, chalky film around the top of glasses
This due in part with the government mandate to remove phosphates from detergent.
Several things can be done to improve the clean appearance of your dishes.
1. Start a wash cycle with no dishes and no soap. Once the wash cycle has stated and water is circulating,open the door and pour in one quart of white vinegar and resume the wash cycle.
2. Use a detergent named FINISH.
3. Use only the recommended amount of detergent.
4. Periodically use a product named LemiShine.
Taking these steps will improve the quality and appearance of the dishes.
On a final note: too hot water temperature can cause etching in glasses and only a lower water temp will prevent new glasses from etching.
Jul 24, 2011 | Dishwashers
Dishwasher is going on 3.5 yrs old, it worked well for the 1st year but for the last year & half it has been leaving gritty residue on all the dishes. To the point, dishes are being hand washed to...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101//
Mar 22, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Which is the best powdered cascade product for the china/crystal setting on my miele?
Most european dishwashers are water conserving and energy saving. You have to be very careful in the type of detergent that you use. Plain, original cascade powder works fine in your Miele. Use 1/2 of the recommended amount, as your dishwasher uses much less water than the american machines that the amounts are written for. avoid cascade with additives such as bleach, or dawn. these additional components in the detergent do not rinse off well with the reduced water quantity, and will leave a gritty white residue on your dishes. Stick with the plain powder. I use Finish tablets with the red powerball, and I dont add rinse aid. These tablets work great in the Miele, asko, Bosch, and other imported dishwashers.
One caution on your china and crystal setting, your manual states that if you want to use the china and crystal cycle, the dishwasher should be connected to cold water only. The temperature of the china and crystal setting is limited to 115 degrees. your hot water is probably much hotter. if your dishwasher is connected to hot water, it will defeat the purpose of the lower temperature cycle. you will get etching on your crystal glasses.
Remember, the Miele will heat its own water one batch at a time. Connect it to cold for energy efficiency, hot for shorter cycle times. but cold only for china and crystal.
Enjoy your machine.
Nov 18, 2010 | Miele G2183SCSFSS Builtin Dishwasher
My dishes and glasses do not come out clean they appear to have some white residue on them...my water softner is working I am using liquid dish washer detergent and jet dry......just feel the washer is not...
If your dishes or glassware appear with a white residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Sep 03, 2010 | GE Dishwashers
Dishs are duty and glasses have white film & dirty
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Please rate the solution if you feel I've helped you
Jun 10, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Residue on dishes/glasses - Hard water? How to clean?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Mar 01, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My stainless silverware and plastic serving spoons, well just about everything has a cloudy, gritty film on them. What can I do?
In addition to the clarification posted by egraber (above), try this....Use the least amount of detergent that you can stand. We usually equate more with better, but not so in this case. The detergent is a bit abrasive, and, over a period of time, will leave scratches and deposits on your dishes, flatware and glasses. If you load the cup like egraber recommends, place detergent in the dispenser. When you remove the cup, test the temp of the water as he recommends, then slowly pour the water off, and check for sediment/soap residue.
Regards, --W/D--
Jul 18, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Residue on glassess etc
changes r that gritty residue is detergant .water should b around 160 to desolve the deter.
Jul 03, 2009 | GE Nautilus 24" Built-in Dishwasher
We have an Admiral Dishwasher that won't clean all the dishes properly. It leaves white film residue on some of the dishes and silverware. Have tried different products to clear this up with nothing...
Apr 04, 2009 | Admiral 24 in. DDB1501AWW Free-Standing...
White Residue
most likely it is your detergent. palmolive eco is notorious for leaving a white chalky residue on dishes. try this out before calling a service tech: put unclean glasses in the dishwasher and in your soap dish and rinse cycle cup put 1/2 cup of distilled white vinegar. if it cleans (or improves) your dishes, then your detergent is the culprit.
Jul 29, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
275 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
